Carbed KA24DE
demo243
Carbed KA24DE
Post by demo243 » 06 Dec 2015 13:28
For photos check out my Project thread-
http://www.the510realm.com/viewtopic.ph ... 55#p265355
Edit**** 1/10/18 Well... Photobucket went and screwed this along with most other car forum posts.... The car is running, but dormant for the moment. Made the move back east and now reside in the Boston area. I dont have a garage in my current place so the car is stashed in CT. With the death of photobucket and most of this thread I think I am going to start a project thread to cover the whole car as I go back and transfer all my photos to Flickr. Stay tuned for a link... to follow here...
Edit*** This started as a want to buy post... but has morphed into a Carbed Twin Cam KA build - Keep tabs for info as I bring my parts together and get this thing going.
Right now the plan is to take the 98 Ka24de I picked up and rebuild it and put it in my '71 510 for street/autoX/trackday fun. I have to give credit to DUKE as alot of the motivation has come from him. Feel free to shoot out questions as I have been doing alot of digging around and researching.
Old post ....
I know there are a few of these floating around out there.
Looking to buy a SideDraft intake manifold to run my Mikunis on a S14 KA24DE. Also looking for a modified distributor to run the carbs.
Looking for other assorted swap parts as well- Header, Radiator, cross member, go fast KA parts
Shoot me a pm if you have any of these lying around.
Thanks!
'71 4 Door - Street/AutoX/Track Day Romper - Soon to be powered by a Carb'ed KA24DE
demo243
Re: Wtb - Carbed Ka24De Parts - Manifold/distributor
Post by demo243 » 03 Jan 2016 17:08
Bumping this up since I am still looking for parts.
Intake, Header, Radiator, Crossmember
DADZSUN
Post by DADZSUN » 04 Jan 2016 14:21
If you're not committed/invested to the DE head, I've got a spare Bogg Yamaha R1 carb intake manifold for KE24e head.
demo243
Post by demo243 » 08 Jan 2016 19:21
Thanks DADZUN ... But already have the Twin Cam torn apart and about to send it to the machine shop. Pretty set on running a DE
Post by okayfine » 09 Jan 2016 11:36
Intake and header are probably going to be custom parts; I've not heard of a DCOE manifold for the KA/DE, and /DE headers exit under the 510's driver's floor. Parts can be modified, but...
Post by Byron510 » 10 Jan 2016 08:27
About 10'yers ago Andy at Specialty Eng asked if I'd make a cast carb manifold for the DE engine, but I never did get his project off the ground. Since then I have seen less than 10 cars completed with a carbed DE power plant. It would have made a good addition, I agree. But not too many takers.
I think you'll be fabricating this component. Do keep us posted.
Byron.
mell00510
Post by mell00510 » 12 Jan 2016 21:36
Contact Mattndew76 here the realm. He will cut you a real nice set of flanges for all of the pieces you are using. Very reasonable, great guy!
OUTthere
Post by OUTthere » 14 Jan 2016 15:02
:idea:
Mattndew76 ka24de carbed intake flange 005.JPG (449.42 KiB) Viewed 6276 times
demo243
Post by demo243 » 14 Jan 2016 20:16
thats a nice looking flange.
Got a couple leads on manifolds right now, but if not custom will be the route.
As for a header from what I have read a OBX header fits ok... with some Image
Also need to decide if I go Electromotive XDI or Megajolt/Ford EDIS .... Definitely going crank fire though.
Need to start a new thread for this build process.
OUTthere
Post by OUTthere » 15 Jan 2016 07:51
Crank fire!
Can usually find a cheap used 240 header and cut it up, they usually beat on them to fit the 240's so cutting one is nothing.
Which crankshaft are you using? Did you find a cam you like and what is the profile?
Mattndew76 intake flange for carb - 240 header 007.JPG (461.69 KiB) Viewed 6247 times
Mattndew76
Post by Mattndew76 » 15 Jan 2016 12:02
The KA24DE Flange shown by OUTthere are $200.00, and I can make adapters to run Mikuni's, Dellorto, Webber, and just about any other side draft.
demo243
Post by demo243 » 15 Jan 2016 17:46
Mattndew76 wrote:The KA24DE Flange shown by OUTthere are $200.00, and I can make adapters to run Mikuni's, Dellorto, Webber, and just about any other side draft.
Cool Ill let you know if I end up needing some flanges
OUTthere wrote:Crank fire!
I just watched a you tube recently that showed you really have to pretty much destroy a header to have any negative effects... been keeping my eye on craiglist for a used header...
Just using the stock crankshaft, the only "drop in" fully balanced one I have found is the crower one for 2k...
For Cam's pretty sure I am going to run the PDM Stage 2 cams- They arent the cheapest but they seem like they have the most thought in them and have the best performance without having to upgrade the valvetrain
Post by okayfine » 15 Jan 2016 18:12
4-into-1 240SX headers are probably a pipe dream in a 510. Tri-Y is a lot more likely to fit without massive work. You'll still need to rework the collector, and possibly far up the collector, to route it into the trans tunnel area. Stock SX routing works only for rally cars.
Post by funwithmonkeys » 15 Jan 2016 19:25
https://www.youtube.com/watch?v=azPKIjxmmdU
It was a pretty cool show....they gained power after the first few bashes to it.
demo243
Post by demo243 » 15 Jan 2016 21:21
okayfine wrote:4-into-1 240SX headers are probably a pipe dream in a 510. Tri-Y is a lot more likely to fit without massive work. You'll still need to rework the collector, and possibly far up the collector, to route it into the trans tunnel area. Stock SX routing works only for rally cars.
There seems to be pretty good info on both the Datsun and 240 sites that a 4-2-1 header suits the ka much better
