Page 1 of 1
Carbed KA24E
Posted: 10 Feb 2017 06:13
by Mr0erick0
Hey guys so I have recently obtained a kA24E out of a Nissan stanza and a 5 speed tranny for my 1968 510.
Any tips or advise going carb?
First time doing anything engine swap related.... or even project related haha
Re: Carbed KA24E
Posted: 10 Feb 2017 18:59
by datzenmike
The rear facing distributor (CAS actually) won't clear the firewall.
Re: Carbed KA24E
Posted: 10 Feb 2017 20:46
by Mr0erick0
Any other suggestions?
Re: Carbed KA24E
Posted: 10 Feb 2017 22:52
by datzenmike
Well it will be difficult to run with the distributor sticking into the heater core. Until this is sorted, the custom oil pan and engine mounts don't matter.
Find a D21 Hardbody KA '86-97? KA24E RWD with it's 5 speed. Has a front mount CAS that you can remove (needs EFI to work anyway, and you don't want that) and replace with an L series EI distributor. The intake has a down draft throttle body you can make a flat aluminum plate adapter for and run a 32/36 Weber on. With this you have made a KA24S
http://community.ratsun.net/topic/46891 ... rbd-build/
Re: Carbed KA24E
Posted: 11 Feb 2017 08:43
by qwik510
Re: Carbed KA24E
Posted: 11 Feb 2017 08:46
by qwik510
Here is another one
http://www.the510realm.com/viewtopic.php?f=31&t=28557
The search tool is your friend
Re: Carbed KA24E
Posted: 13 Feb 2017 12:42
by Mr0erick0
Which would be a lot easier to install? Weber 32/36 or the R1s?
Re: Carbed KA24E
Posted: 18 Feb 2017 00:26
by Mr0erick0
datzenmike wrote:Well it will be difficult to run with the distributor sticking into the heater core. Until this is sorted, the custom oil pan and engine mounts don't matter.
So I could get the head/distributor out of the hardbody and swap it with this KA from the stanza correct?
Thinking about going with R1 carbs as well!
Re: Carbed KA24E
Posted: 18 Feb 2017 11:44
by okayfine
FWD cars tend to mount their engines very differently from RWD applications. FWD block probably won't accept a RWD distributor, either.
If you're new to swapping 510s, you're inviting trouble attempting to go down a path that few of us have traveled. There are plenty of RWD drivetrains out there and it would be a ton less work simply going with one of those versus trying to rework your FWD engine, nevermind the FWD trans absolutely won't work anyway.
Re: Carbed KA24E
Posted: 18 Feb 2017 13:22
by Mr0erick0
okayfine wrote:FWD cars tend to mount their engines very differently from RWD applications. FWD block probably won't accept a RWD distributor, either.
Guess I'll just find a KA out of a pick up lol
Time to put the current KA up for sale
Re: Carbed KA24E
Posted: 08 Mar 2017 22:21
by grimlid
Thanks Okayfine and Datzemike for the tips. I have a line a ka24e in a 91 D21 with 5spd and going that route.
Ive seen so many Nissan fwd's with sweet motors and wondered why I couldnt find any build threads involving these engines. I assumed it was just the mounts and and/or transmission issues.
I had a hunch it would be a pain in the neck though.
