SR20DE swap
Fred_L-P
SR20DE swap
Post by Fred_L-P » 21 Nov 2017 20:30
I've been looking around for a well documented SR20DE swap... but there is so much SR20DET pollution out there I can't find anything remotely interesting.
Can anyone point me into the right direction?
Thanks
spriso
Re: SR20DE swap
Post by spriso » 21 Nov 2017 21:49
If I can ever find the time, I'll do a write up on Brian's S15 SR20DE swap that we did into his 510-- it turned out fantastic!
Until then, here are some photos you can see:
https://www.flickr.com/photos/15007794@ ... 0485317798
Michael
Michael Spreadbury
Spriso Motorsports
www.spriso.com
Fred_L-P
Re: SR20DE swap
Post by Fred_L-P » 22 Nov 2017 05:25
Thanks Michael! Pictures are great, it does help a lot.
That's exactly the kind of swap I'd love to read about. Waiting for your write up :wink:
Re: SR20DE swap
Post by icehouse » 22 Nov 2017 09:07
I love my NA SR swap! The motor was originally purchased from Up Garage back when they still imported motors. I'm amazed at the abuse it can handle. As far as install its the same as the KA.
Re: SR20DE swap
Post by icehouse » 22 Nov 2017 09:09
spriso wrote:If I can ever find the time, I'll do a write up on Brian's S15 SR20DE swap that we did into his 510-- it turned out fantastic!
Michael
Aren't the S14 and S15 NA SR's the same? Unless you find one of those rare Autech SR's?
spriso
Re: SR20DE swap
Post by spriso » 22 Nov 2017 09:17
Yes, the S14/S15 Engines are 99% the same, really the only difference is the bolts on valve cover-- the S14 uses studs and nuts, and the S15 uses thru bolts.
The rest of the difference is in the tuning in the ECU which gives 5 more PS ~4-5hp, hence the 165 PS rating on the S15 engines.
Michael
Michael Spreadbury
Spriso Motorsports
www.spriso.com
Fred_L-P
Re: SR20DE swap
Post by Fred_L-P » 22 Nov 2017 10:23
So if it's the same as the KA, the stock headers should clear the steering box? I've heard people saying they needed a custom headers.
Re: SR20DE swap
Post by icehouse » 22 Nov 2017 14:26
Fred_L-P wrote:So if it's the same as the KA, the stock headers should clear the steering box? I've heard people saying they needed a custom headers.
Yep just gotta relocate the O2.
Re: SR20DE swap
Post by icehouse » 22 Nov 2017 14:27
spriso wrote:Yes, the S14/S15 Engines are 99% the same, really the only difference is the bolts on valve cover-- the S14 uses studs and nuts, and the S15 uses thru bolts.
Michael
Good to know! Wish they would have done a VE RWD!!!!
