SR20DET Oil Pump Priming
- PoorMtnKid
Back in April I took my engine to a local machine shop for a full rebuild. Just this weekend I fired the engine for the first time but I'm not getting any oil pressure throughout the system. I have tried to search the typical SR forums about priming the pump and most lead to just removing spark/fuel and cranking for so many seconds so many times and boom your good to go...... Well that is not happening. I have an oil cooler so I used my air compressor to blow air through both side of the feed and return lines on it. When I blow through one hose I can hear it blowing bubbles in the pan. I then added oil to the lines and blew through the other hose and oil came out of both the turbo feed line and also above the cams in the head. So I know the passages are clear, yet the pump does not want to pull oil through.
Does anyone out there have experience with the SR oil pump and how to jump start them? I have read to pump oil through the fitting the oil filter mates to, I will try that soon but I'm really frustrated with this thing and would like to cut to the chase if possible.
Re: SR20DET Oil Pump Priming
Assuming the oil pump works, push oil back through the pump instead of air. That will fill it and the pick up tube.
Just checking, are you pulling oil from the pan - cooler - pump - Filter => engine?PoorMtnKid wrote: ↑07 Oct 2018 19:52When I blow through one hose I can hear it blowing bubbles in the pan.
Or is the oil going from the pan - pump - cooler - filter => engine?
Just clarifying.
- PoorMtnKid
I was trying to research that also on the SR20's but couldn't find anything yesterday. This is how I think it goes, someone correct me if I'm wrong.Byron510 wrote: ↑07 Oct 2018 21:02Just checking, are you pulling oil from the pan - cooler - pump - Filter => engine?PoorMtnKid wrote: ↑07 Oct 2018 19:52When I blow through one hose I can hear it blowing bubbles in the pan.
Just clarifying.
Pan-pump-filter-cooler- engine.......
I have read on other forums of people using the turbo feed line hole on the block to fill oil back until it spews out. So I may try that later tonight.
I built a tank that holds 1 gallon of oil. The tank has a line off the bottom I screw into the oil pressure sending unit hole in the block. The tank has an air supply line at the top with a valve, I hook my air compressor up to it and pressurize the tank. Some engines you can see oil start to pool up in the head through the oil cap hole, some you have to take the valve cover off. I've used it few times with great success.
A good buddy of mine who is the best shade tree mechanic ever! He always has a trick to do the job with no extra tools, told me he fills the engine with way to much oil, like a gallon extra, enough so he knows the level is above the oil pump, that way it self primes do to the natural level of the oil. Then he cranks it till he gets oil pressure, drains the excess oil and fires it up. I've only attempted this method on engines I don't care about! haha.
My two ideas.
My two ideas.
- PoorMtnKid
I did read of the overfill method as well, just seems odd to have to go through that. I was thinking of making some type of tank like you mentioned that I can hook up to my oil cooler line or turbo feed line and do what your saying. Was the flow described the correct way the oil flows on an SR? What could the machine shop have done incorrectly to not have the oil flow? The only thing I read is there is an O Ring that if missing the pump just sucks air and will not create a vacuum to pull the oil from the pan.......icehouse wrote: ↑08 Oct 2018 08:06I built a tank that holds 1 gallon of oil. The tank has a line off the bottom I screw into the oil pressure sending unit hole in the block. The tank has an air supply line at the top with a valve, I hook my air compressor up to it and pressurize the tank. Some engines you can see oil start to pool up in the head through the oil cap hole, some you have to take the valve cover off. I've used it few times with great success.
My two ideas.
Oil pump priming on a SR20DE/T is very important and we developed this method years ago when we start an engine that has been sitting a long time or that has had the oil pump replaced that has worked well for us.
What we do is use a simple in-line pump that is driven with a cordless drill-- we then replace the stock SR20 oil filter housing with an aftermarket unit that looks like this (you can buy Chinese knock offs for a very reasonable price on eBay):
This block is mounted with 4 socket head cap screws and is easily removed and replaced.
Hook up some vinyl tubing to the inlet and outlet of the housing, stick it into a quart of clean oil and spin the pump until you see oil dripping out of the camshaft oilers.
Here is a quick video of the process that shows how we do it:
https://www.youtube.com/watch?v=KBRERtNu500
Hope that helps,
Michael
Hope that helps,
Michael
Michael Spreadbury
Spriso Motorsports
www.spriso.com
Spriso Motorsports
www.spriso.com
- PoorMtnKid
Hey Michael
Thanks for the suggestion, I was able to come up with a plan. So I have a oil cooler adapter block similar to this already that runs to my oil cooler, I was able to source an AN fitting that can connect to the end of the IN line and I was able to pick up some tube and a drill pump. I'm going to try your method later today.
One thing I don't understand though is pumping through the IN port pushes the oil into the engine journals, how does filling this help pre oil filter down the pump and pick up tube? Or are you saying I need to pump oil into the IN and OUT ports to just try and fill the entire system? Just trying to understand if filling this helps create a vacuum or something.
We have used this technique on all the SR starts that we do, and it has worked perfectly... let me know how it works out for you...
Michael
Michael
Michael Spreadbury
Spriso Motorsports
www.spriso.com
Spriso Motorsports
www.spriso.com
- PoorMtnKid
No luck =(
I tried this method and was able to get oil coming out of the camshaft oilers, turned the car over and still get no pressure. During the replacement of the oil pump what could go wrong, missing, incorrect , etc. to cause this problem?
On thing I read is there is an O-ring that if missing the pump would just suck air and not allow it to pump the oil....... Pretty upset right now with this entire process as the damn machine shop said it would take 6 weeks and it took 4 months. And now that I'm getting it in and buttoned up I'm running into this problem.
- PoorMtnKid
Latest update. I took off the pan to inspect the pick up tube for cracks, it looked good but the o ring was obvious it was never replaced. I have ordered the later model sr pick up while I'm in here. The plan at this point is to put the later style in, bolt back up and try again using the drill pump set up. If results are negative my next direction would be to inspect the front cover/pump area.
