Page 1 of 1
Fuel tank/evap setup needed?
Posted: 03 Jul 2019 17:57
by broke
Hi all,
Still working on plumbing for EFI, I'm not really loving the weird labyrinth of clear PVC tubing for the tank ventilation.
I was thinking about removing it all and just running a check valve like a PCV valve or something with a small breather filter off the top of the tank instead.
Will this work, or is this a recipe for disaster? Only possible negative I can see is if the valve doesn't fully seal in the closed position I might have some fuel vapour smells from time to time.
Re: Fuel tank/evap setup needed?
Posted: 04 Jul 2019 12:53
by JordanTr
I took a breather from a newer car (Mazda 3 iirc) and ran it out below the trunk floor. At least the inside of the car doesn’t reek like fuel on a hot day now.
Posted: 04 Jul 2019 13:52
by bertvorgon
IF...you still have the evap tank under the rear parcel shelf...I ran a line to that from the fuel tank vent...then from the evap tank out and down through the trunk floor...to exit at the rear of the car underneath. This does two things..get rid of fumes through the air stream AND...if you ever put the car on the roof....keeps the fuel from spilling out...bit of a good safety thing too.
Posted: 04 Jul 2019 15:29
by broke
bertvorgon wrote:
04 Jul 2019 13:52
Interesting. None of mine have ever had any kind of tank, just this weird labyrinth of tubing that dumps through the floor eventually. I'm sure there's a reason for it, but it certainly doesn't look very functional
Posted: 04 Jul 2019 15:56
by bertvorgon
I have a 1973, so for sure had the pollution systems on my car, not sure when the trunk evap tank went in. You can see it above my fuel tank, was perfect for dealing a lot of issues.
