Datsport 1/4 window glass to frame seal issues.
eastbaysolo_73
Post by eastbaysolo_73 » 17 Apr 2018 16:14
Ok fellas I have tried two attempts at installing the Datsport glass to frame seals. I have not had any success installing them. I've been close but obviously not close enough because I'm posting this here for some help. I don't know what Im doing wrong but I can get that dam rubber seal to move forward enough to seat in place. The seal keeps binding at the window latch cut out. The seal need to move forward so that the cut out is in its correct place on the behind the latch. I have the screws removed so the seal doesn't get snagged on them as the seal slides forward. Unfortunately it keeps snagging in that spot no matter how much soap and water I use it will not move forward. I used a rubber mallet as well and no luck. Is there a trick to installing these seals because I'm at wits end with this. So far all the other Datsport seals have been a breeze to put on. These on there other hand are a nightmare!!! Here's a two photos to show you where the seal is getting caught or needs to move forward more.
Sorry for the shitty photos. I was in full rage mode lol from frustration. I will take better photos later. I put the windows up and walked away. I did the first time I tried and that was 5 months ago. Any help will be appreciated.
Re: Datsport 1/4 window glass to frame seal issues.
Post by Three B's Racing » 18 Apr 2018 05:33
Try placing the cut outs behind the latch first then insert the rest of the seal. I've never installed these before so!!!!
eastbaysolo_73
Post by eastbaysolo_73 » 18 Apr 2018 09:38
Three B's Racing wrote:Try placing the cut outs behind the latch first then insert the rest of the seal. I've never installed these before so!!!!
lol thanks but the seal need to be put on the glass and slid into the frame to install it. If I could get away with the seal being in place in the frame yes that would be ideal. But after many tries fiddling with it. It wont work but thanks anyway man.
MikeY
Post by MikeY » 18 Apr 2018 09:48
I know it doesn't help you but I had a hard time replacing used stock rubber. Lots of lube. I used dish soap.
eastbaysolo_73
Post by eastbaysolo_73 » 18 Apr 2018 12:16
MikeY wrote:I know it doesn't help you but I had a hard time replacing used stock rubber. Lots of lube. I used dish soap.
Thanks MikeY Gonna try just dish soap no water.
iceD
Post by iceD » 18 Apr 2018 18:43
Are you controlling your breathing while you are doing this exercise? It is very important to continue breathing while attempting all modifications.
ice D
eastbaysolo_73
Post by eastbaysolo_73 » 18 Apr 2018 20:07
iceD wrote:Are you controlling your breathing while you are doing this exercise? It is very important to continue breathing while attempting all modifications.
ice D
Lol yes I was till I pulled it apart for the third time and I kept having the same issue. But yes BREATH IN BREATH OUT!! :mrgreen:
eastbaysolo_73
Post by eastbaysolo_73 » 20 Apr 2018 13:13
Also what are you guys using for replacement screws for the frame? I got some of a thread I can't find anymore for the window latch to frame mount. But they are to short for the back side of the frame. I guess I could try and find longer ones. Just curious to see what other people are using. Got one done with tons of Dawn soap. Just need the screws to lock in the back piece.
eastbaysolo_73
Post by eastbaysolo_73 » 30 Apr 2018 12:20
So I got this link from BAZ and it has been a tremendous help.
http://www.the510realm.com/viewtopic.ph ... 55#p251955
Also Colbino was nice enough to answer my questions and give me some guidance. I have one fully done and as good as I could get it. One left to do lets see how this one goes. The outer rubber from Datsport was a breeze in comparison to the frame to glass seal.
Here's some tips from Colbino
Hey Vince,
Its been awhile since I did that super annoying task! Let me see what I can recall.
The first window I did went in easier then the second one. I made sure to do it on a cool day to minimize the rubber expansion. I even placed it in the freezer while I was prepping my work area and the frame.
Make sure you have the correct length bracket screws (still available from nissan) so that you don't have them sticking out too far and interfering with the seal.
Double check your inner lip is perfectly smooth and free of any old paint or dried weatherstripping so the seal can slide freely along the track.
Before you start the job put the meal end pieces on the frame and verify that you can freely screw them into the rest of the frame. I tried each one in both frames and one fit better then the other. This may not make any difference in your case, but after dealing with the annoying task of getting the seal in you'll want to make sure that the last part of getting the back piece in, lined up and screwed on doesn't end in you having to start over because you cannot get the holes to line up. It happened to be several times.
I put my bracket on and cinched it down and then lubed up everything really well. I made sure every area of the channel was slippery. Try not to get any excess on the outside where you're holding the frame so it doesn't slip around.
I then lubed started with the far bottom corner and showed it in there as far as I could. Then start laying the rest of the seal while constantly pushing the seal towards the starting point. The seal feels like it's a bit too long, which it may be or it just stretches over time. Not sure. Either way your goal is to keep the seal from stretching out.
Now you will want to lube up the inner channel where the glass will slide into. If you have a buddy it will make things easier as he can help pull the frame apart while you slide the glass into the seal. Once the glass is it you will probably have to start "walking" the seal back towards the far lower corner that you started with. Your goal is to remove as much of teh seal slack as you can so that you can get the back metal piece on and finish the install. If you have a rubber mallet you can tap the end of the glass into the seal. Also, a plastic paint scraper or some sort of rounded piece of hard plastic will help you push the seal towards the corner - push down on the rubber and slide towards the starting corner; about 6mm at a time. Take your time and do this to everywhere along the seal and always going towards the corner. The upper curve is where I had a gap and needed to always work on. Towards the end I would put the end of the glass on my stomach and pull the frame towards me just to get the glass to slide into the seal that last half of an inch. It's a messy job, and over time you'll want to spray some more lube if it starts to dry. I actually think dawn may work well too with this process. You can also use wd40 as it's not going to harm the rubber.
