Page 16 of 16
Re: Chinese made aftermarket windshields
Posted: 07 Dec 2017 05:29
by Three B's Racing
I've been running a Pro Source windshild since `97 and though it does have pits and one chip I chock that up to yearly runs to Summit Point WV since `99, Road Atlanta 2010, Canby 2017, North Carolina-Maryland runs just to see friends and typical New Hampshire, Massacheuttes, Maine and Vermont roads and highways. The pitting seems typical to me as compaired to the original windshild it replaced which was only 8 years older but had less miles on it and was in worse shape than the Pro Source I'm running. I have a spare Pro Source I'll be using when that time comes.
Posted: 07 Dec 2017 06:22
I have installed a Pilkington screen on one of my cars, and what I can say against the Chinese glass is that it is thicker and sits in the OEM rubber much better than the Chinese ones do and the Pilkington is closer to the OEM glass thickness. It’s still a bit thinner, but it’s a lot closer.
As far as mileage and wear, it’s unfair to report as this car has been driven less than 500 miles since I changed that glass over a year ago. But on fit alone its worth the buy.
I did a write up on that install, I’ll see if I can dig it up.
Posted: 08 Dec 2017 06:44
by Three B's Racing
Byron510 wrote:I have installed a Pilkington screen on one of my cars, and what I can say against the Chinese glass is that it is thicker and sits in the OEM rubber much better than the Chinese ones do and the Pilkington is closer to the OEM glass thickness. It’s still a bit thinner, but it’s a lot closer.
Hey Byron, your right on the thickness difference. As far as fit in the seal I can't remember that part but I can tell you this, it doesn't leak.
Posted: 08 Dec 2017 07:38
by anguso
Thanks guys,
I'd love to see any writeup on the install, but at this point I'll likely pay someone with real experience to do the installation.
A quick question - given the thread title, I'm unlikely to get much traffic from someone who might be interested in new glass but hasn't done a decent search. Is it OK to post in the classified section to get a bit more visibility?
subject line is included in each post - subject line for 1st post in a thread sets the title field for the thread...
Posted: 08 Dec 2017 08:16
by 510rob
You can edit the title by going back to your first post and editing the title in that first post.
Posted: 08 Dec 2017 17:52
It’s not a how to install thread, but I did note the glass thickness and a few other bits on the installation.
I used a really dine, tight weave 3/8” nylon rope this time, it work d quite well.
viewtopic.php?f=3&t=11938&p=254103&hilit=L13#p254103
Posted: 09 Dec 2017 17:50
by funwithmonkeys
I just put a Chinese one in my car. It was the first time I had ever attempted something like it and after reading a couple of write ups on here about it it took me a total of 8 minutes after the rubber and stainless trim was on to do it by myself. I really didn't think it was going to be that easy, especially by myself. It fits well but is thinner and lighter then the Pilkinton that came out. That did make it easier to handle.
Posted: 10 Dec 2017 09:39
by 510rob
Norm, you took a Pilkington out and put in a Chinese one? Do tell...
Posted: 10 Dec 2017 13:15
by funwithmonkeys
It was probably 25+ years old and like trying to look through a white sheet when driving into the sun.
Posted: 10 Dec 2017 23:02
I know what you mean about the thinner Chinese glass going in easy - when I installed one for a club member it felt like it fell into place -
Thrown from a distance! Trust me, a stock thickness windshield takes a bit more time to seat those corners properly :-)
Posted: 11 Dec 2017 10:24
by RMS
on a side note: picked up a nos gasket from a local guy with a shop. installed it into 6inches of rust less than a year ago. yesterday the gasket looked a bit funny I pushed on it and it moved. closer inspection showed the gasket had split. along the top edge were it grabs the pinch weld.
Posted: 12 Dec 2017 13:10
by KiKiIchiBan
Does anyone make glass for the JDM coupe?
Posted: 12 Dec 2017 17:52
by tycot1
in respect to chipping and pitting, its not just the thickness of the glass that makes it better, it is also glass content quality that makes a better windscreen.
