Oversized Alt Pulleys
Derek
Post by Derek » 19 Jan 2010 16:15
My dad is looking for one of these for his 240Z vintage racer. I know Byron has made them before, but does anyone know if an off-the-shelf or easily modifiable (IE bored, make some spacers) off-the-shelf solution exists?
Thanks!
hang_510
Re: Oversized Alt Pulleys
Post by hang_510 » 20 Jan 2010 09:41
subscribed!
i want one (or 2).
the PO made his, but its not concentric :evil:
Post by okayfine » 20 Jan 2010 10:01
Derek wrote:does anyone know if an off-the-shelf or easily modifiable
Figure you could swap in a different diameter pulley from another L-series alt? What's the diameter of the one you have? Get some of the L-series guys here to measure their's and come up with a good swap.
hang_510
Post by hang_510 » 20 Jan 2010 11:34
okayfine wrote:Figure you could swap in a different diameter pulley from another L-series alt?
everything i looked at (as a direct replacement from nissan) had the same pulley...
maybe a alternate alternator manufacturer???
Post by defdes » 20 Jan 2010 13:10
This site has pulley's and a calc for RPM's.
http://www.powermastermotorsports.com/p ... lleys.html
Post by bertvorgon » 20 Jan 2010 18:54
I can measure my alternator pulley tommorrow for you if you like, Dave Christie made mine, and Specialty made my water pump pulley. Dave and I never had a problem with our alternators, after slowing them down, and that is with turning the engine to 8,000.
Edit: I see on one of my other pictures it is 4" in diameter
4" pulley
larger alternator and water pump pulleys.
Post by 510rob » 20 Jan 2010 19:54
what type of crank pulley is that Keith?
Rheis
Post by Rheis » 22 Jan 2010 14:03
510rob wrote:what type of crank pulley is that Keith?
Yes what is that? It looks like some sort of harmonic balancer
