Stereo Install Time!
oaklandsyd
Post by oaklandsyd » 21 Feb 2010 15:50
KA is running *fingerscrossed*, so I'm finally on to the fun parts.
How do you guys mount your Stereo head units into the standard 510 console? My last dime had a standard JVC, but I can't recall for the life of me how it actually hooked into the dash.
My current 510 has the orig. AM mono set up, and there is about 5" of depth to fit a new head unit (which generally run about 7")
Are you guys modifying the dash with some spacers to account for the depth?
Any ideas will help. I'm thinking a vacuu-form machine might be fun to have for this project!
PS. there will be no 'hidden' receivers, no amps. No glove box or under seat remedies. I've got no room but the stock locations & I'm dead set on the Head Unit + 2 speakers combo.
Will provide pics on request.
tycot1
Re: Stereo Install Time!
Post by tycot1 » 21 Feb 2010 16:03
i have never had a problem fitting in any single din head unit. the wiring should be right there with the exception of an ignition wire i think. even if it isnt there all you need is a clean ground, a full time power source for memory (there is a radio fuse at the fuse box, follow it to your dash), and an ignition wire at your steering column. put your test light into a wire that provides you with power when the key is in the accessory position, as well as the on position, and of course when the car is actually running too. i think the wire is white with a red stripe. dont use those two wire clip on things as they lead to future problems, the end up breaking the wire. take that radio panel off and cut it from the back side, there should be enough space for any head with the exception of a harness issue or rca's getting in the way. good luck.
oaklandsyd
Post by oaklandsyd » 21 Feb 2010 16:32
I made a miss measure... i actuall have 6.25" of space, so I need a kick out from a spacer of about .25"-.5".. Not nearly as dramatic as I thought!
Thanks for the info. My next question was wiring.
Does anyone run a relay to the stereo? My last one ran off the Lighter positive, but this 510 doesn't have a lighter. It looks like I've got two Light Blue wires that are unoccupied, guess I'll check those and see what their deal is.
Post by okayfine » 22 Feb 2010 07:54
oaklandsyd wrote:Does anyone run a relay to the stereo? My last one ran off the Lighter positive, but this 510 doesn't have a lighter. It looks like I've got two Light Blue wires that are unoccupied, guess I'll check those and see what their deal is.
Don't rig it, do it right. Imagine how much you'd hate it if you bought a car with a hacked-in radio setup. You have an AM radio that already has switched power to it. Follow Tyson's advice WRT the memory backup source and what else do you need besides a ground?
Post by James » 22 Feb 2010 08:19
I once made a spacer out of black styrene - which was about 1/4" thick. I beveled it back so the front of the spacer met the surround nicely and you could never tell.
Rheis
Post by Rheis » 22 Feb 2010 09:15
I bought a cut din because I didnt want to cut my nice orginal one ... I also used the original radio mounting brackets and screws by drilling some new holes in the brackets. On my other car I bent some up out of scrap
tycot1 wrote: dont use those two wire clip on things as they lead to future problems, the end up breaking the wire.
do you mean the crimp style wire splicers or taps
hang_510
Post by hang_510 » 22 Feb 2010 09:35
double check!!! but i think those are the correct wires for constant power.
youll be fine w/o a relay for this setup.
i hate those taps!!! :evil:
learn to solder!
