Eyebrow trim/fender restoration
- two_68_510s
I had purchased an old damaged but not rusty fender for 10 bucks.
I decided to see if I could bring it back! The fender overall is very good, just that one little dent. Close up of damage:
- two_68_510s
Re: Eyebrow trim/fender restoration
Separated the eyebrow trim, two small rusty screws.
If there is a bump/dent I go to the back of it (the "male side of dent") and give it a well placed and very small poke with my tool of choice and a small hammer..
I have shaped some old chisels into various blunt shapes to use. You will find it to be pretty instinctive. Use some finesse and don't stretch the metal. Never "pinch" it between your anvil (I use a piece of railroad rail, makes a nice ring) and your hammer/tool, that will stretch it. You use the anvil to backup the blow, but keep the energy input lower then you think you should, you will be surprised. Also, it takes lots of very small blows to accomplish this, not a few big ones.
Just bump it back into position. You can feel the difference. The metal does have a memory, if you coax it. It you hit it extra hard, it will stretch or distort a little and make it tougher. I have found it is hard to "shrink" stainless trim if you go too far, like you can sheet metal, so go slow. After hitting it about 10,000 times you can get pretty close, then you can sand a little to find high and low spots and hit it again.
The process I use for trim, self taught, is to look for the point of impact and work the dent backwards in time, kind of a forensic approach If there is a bump/dent I go to the back of it (the "male side of dent") and give it a well placed and very small poke with my tool of choice and a small hammer..
- two_68_510s
Top part polished, bottom only sanded
The damage and my twisting it back into place caused a section of one corner to break out, I will TIG a little repair in there
Amazing stuff I have a few of these that are not nearly as bad as this - have to get to work!
- two_68_510s
Damn things are getting expensive!
Now, to go after that fender!
- kayakdude07
I thought I worked hard to fix up the eyebrow trim I had.
Nice work Joel!
Nice work Joel!
Mad skills, yo!
Holy shnikies!!!
Holy shnikies!!!
In general, metal shaping/finishing is a lost art, to do it correctly is a very time consuming job = $$$. Most people won't or can't pay for the talent. There is a guy (one man shop) here that just does metal finishing,no bondo,no painting. Has customers from all over the world. Works on a retainer system, you bring the project and some large amount of money and works off the retainer. When the money runs out, you bring some more. The guy does some amazing work. I saw a client of his bring in a clam shell fender off of some high priced car, that looked like a semi drove over it. Weeks later looked like it was brand new, nice shiny bare metal ready for paint, just unbelievable work.
Joel, thanks for documenting the process!
w0w!
i was happy with my results using bamboo stakes to pound out the dents and creases, until i saw yours.
- two_68_510s
Now a little work on the fender:
- two_68_510s
- two_68_510s
- two_68_510s
All I can say is WOW!!!!!.Nice work.
