1/4 window stopper?
dodgydan
1/4 window stopper?
Post by dodgydan » 10 Jan 2014 16:12
both our 2dr 510's are missing the small bumper/stopper piece that's sits below the 1/4 window. I believe its there to support window when its closed and stop rattles etc. there are 2 small holes for screws/rivits ? anyone have close up picture of this, or can give me dimensions and material so I can make some?
Thanks.
Re: 1/4 window stopper?
Post by okayfine » 10 Jan 2014 17:27
The Parts Catalog shows the bumper, but doesn't give a part number or anything, which is strange. Typically that means that part is cited somewhere else, but darn if I can find it.
2-Door Rear Window.jpg (89.22 KiB) Viewed 2086 times
finn
Post by finn » 10 Jan 2014 18:56
Appears to be 2 1/4" long 7/8" wide 3/16 deep. But mine are worn.... I would think micarta is the best to use but a soft plastic would work.
'69 2dr KA24DET
dodgydan
Post by dodgydan » 10 Jan 2014 19:59
ya I couldn't find a part # or a better pic.
thanks, I can try making some to those measurements. are they wedge shaped or the same thickness?
Post by Byron510 » 10 Jan 2014 23:59
Dan,
I recently dug these out for the Greg Terry Memorial Build. Since the car had very little use (15K miles), I'd be happy to measure mine as they are in great shape. I'm traveling until next weekend for work, but I'm sure we can come up with an answer if you don't find something sooner.
Let me know.
McWicked
Post by McWicked » 11 Jan 2014 02:04
I think the PN is 78136-22200. NLA of course.
If nobody has posted up a pic by Sunday, I can take a pic of the ones on my stocker.
-McWicked
Post by bertvorgon » 15 Jan 2014 07:56
They..mine..appear to have ever so slight a taper, which would make sense when I closed the window, kinda act as a bit of a wedge UP, keeps the Window from drooping from what I can ascertain.
2 small screws are used to fasten it, counter sunk of course.
Finn's dimensions are close to mine.
IMGP7407 (Large).JPG (120.86 KiB) Viewed 2000 times
IMGP7406 (Large).JPG (191.88 KiB) Viewed 2000 times
IMGP7405 (Large).JPG (189.23 KiB) Viewed 2000 times
Post by bertvorgon » 15 Jan 2014 07:57
last, hope that helps.
This was also a good excuse to clean that ledge...I never open that rear window!
IMGP7409 (Large).JPG (124.03 KiB) Viewed 2000 times
IMGP7408 (Large).JPG (156.47 KiB) Viewed 2000 times
dodgydan
Post by dodgydan » 15 Jan 2014 12:59
:) thanks all, that's enough info so I can make some up.
CHEERS, gotta love the realm community.
toylet
Post by toylet » 25 Jan 2014 20:53
I need a set of these... anyone interested in making some $$
toylet
Post by toylet » 20 Feb 2014 14:05
bump...some one make these. these would sell like hot cakes, since they wear out on most all 2dr 510s.
Post by bertvorgon » 20 Feb 2014 16:50
If you have a modicum of fab skills...just go to a local plastic shop, or scrounge up some plastic this rough size, the file/cut/drill and make the piece. Then, just file a slight taper to it. This piece is not a critical rocket part, so as long as it is close, there is enough tolerance in the window to move around a tad.
If BloodyDick Montana really is off the map,,, scrounge around the house...I would look at one of the white cutting boards..buzz a rough section out of it, file it...bingo, two window wedgies.
I can't tell you how many projects got finished with something scrounged from home....and don't tell my wife about her cookie tray...... :wink:
It would take me an hour to make two......and what would I charge someone.....if I paid myself 25.00/hr, plus material, plus mailing...would someone really pay 40.00 for them. it cost's me almost 7.oo bucks to mail a small article to the states.....
McWicked
Post by McWicked » 20 Feb 2014 17:03
toylet wrote:bump...some one make these. these would sell like hot cakes, since they wear out on most all 2dr 510s.
I doubt they'd sell like hot cakes. If there's one overarching theme of the greater 510 community, it's that collectively we're cheapskates. To make matters worse, we're a relatively small community. That makes for a tough business model.
-McWicked
dodgydan
Post by dodgydan » 20 Feb 2014 17:37
plus its fun to make stuff for your own car :D
I made some out of nylon I scrounged. thanks to you all for examples. look factory to me and took an hour or so. ill post a pic. when I can.
toylet
Post by toylet » 20 Feb 2014 19:28
Im a cheapskate.. but I like most 510 guys on here have no problems throwing hard earned cash on there 510. I dont have the fancy machines to make a "QUALITY" set. So why waste the effort.
