Body plugs and drainage plugs
Chadsinto510s
Post by Chadsinto510s » 24 Feb 2014 08:23
Heater holes (if you are deleting the heater and aren't welding the holes shut) and floor drainage holes and a few others in a 1973 2 door 510 sedan (should apply to any year and possibly any body style):
74942-04100 or 77700-89914. Either one will work. Readily available from Nissan.
Rear diff mustache bar stud covers (kind of under the fuel tank)
01658-00041 NOT the same as factory original but fit just fine. Readily available.
I have pics that I'll try to post soon.
toylet
Re: Body plugs and drainage plugs
Post by toylet » 24 Feb 2014 09:09
what about the really little floor plugs in the truck area ..there is 2 of them? how about the frt door bumpers there is a listing for 2 different part numbers. which one is it?
Chadsinto510s
Post by Chadsinto510s » 24 Feb 2014 09:40
toylet wrote:what about the really little floor plugs in the truck area ..there is 2 of them? how about the frt door bumpers there is a listing for 2 different part numbers. which one is it?
I didn't look for those yet. Got a size in millimeter? I saw those holes yesterday while I was test fitting the above mentioned ones. I think I have a number for the small hole but need a size or time to do a test fit and snap a pic.
toylet
Post by toylet » 24 Feb 2014 12:37
Chadsinto510s
Post by Chadsinto510s » 24 Feb 2014 13:28
That's what I thought they might be when I saw the holes yesterday. That number is:
74942-10900 Readily available from Nissan.
Edit: To be clear this number is for a 20mm hole. Will work on any 20mm hole you'd like to fill with them.
toylet
Post by toylet » 24 Feb 2014 14:16
I think those go in the interior side part of the car not on the floor pan.. I am going to do some measuring when I get home.
Chadsinto510s
Post by Chadsinto510s » 24 Feb 2014 15:19
toylet wrote:I think those go in the interior side part of the car not on the floor pan.. I am going to do some measuring when I get home.
I'll take one of the 74942-10900 plugs home with me and do a test fit etc. Visually the holes looked the same but.....
toylet
Post by toylet » 24 Feb 2014 18:57
Looks like they are like 14 of those 20mm plugs. Still trying to find the part number to this plug that goes next to fuel tank.
http://www.ebay.com/itm/Datsun-240z-510 ... 04&vxp=mtr
Chadsinto510s
Post by Chadsinto510s » 25 Feb 2014 06:41
toylet wrote:Looks like they are like 14 of those 20mm plugs. Still trying to find the part number to this plug that goes next to fuel tank.
The plug in the link you provided I believe to be:
01658-00041
There is also another plug under the gas tank:
77700-89900
Chadsinto510s
Post by Chadsinto510s » 25 Feb 2014 06:47
The 74942-10900's fit the holes in the trunk perfectly.
Chadsinto510s
Post by Chadsinto510s » 25 Feb 2014 08:06
Pics as promised:
77700-89914 INSTALLED_IN_SPARETIRE_HOLE (Medium).jpg (119 KiB) Viewed 5074 times
74942-10900INSTALLED (Medium).jpg (152.41 KiB) Viewed 5074 times
74942-04100HEATER (Medium).jpg (74.34 KiB) Viewed 5074 times
74942-04100B INSTALLED IN FLOOR REAR SEAT (Medium).jpg (88.63 KiB) Viewed 5074 times
74942-04100 INSTALLED IN FLOOR (Medium).jpg (83.88 KiB) Viewed 5074 times
01658-00041REAR_DIFF_MUSTACHE_INSTALLED (Medium).jpg (97.95 KiB) Viewed 5074 times
Mustache bar stud hole in trunk under gas tank.
01658-00041 (Medium).jpg (100.13 KiB) Viewed 5074 times
eastbaysolo_73
Post by eastbaysolo_73 » 04 Jul 2014 17:35
Nice thanks for sharing the info they look great.
My build thread
Nor Cal Meng !
toylet
Post by toylet » 27 Sep 2015 15:28
What is the part number for the big body plug in the spare tire well?
edit found the perfect one 06212-5500P
Lswone
Post by Lswone » 12 Dec 2019 21:22
Just wanted to share part# 74942-04100 was a perfect fit for the floorboard holes in my 69 510 Wagon.
Thanks for the tip Guys!
cartel
Post by cartel » 07 Feb 2020 20:41
this should be at the top- sticky as it has the part #s..
Mike Gibson
