Battery Cable Replacement Options
510wizard
Postby 510wizard » 23 Aug 2015 08:14
Looking for input on negative battery cable replacement. My cable end has seen better days after 42 years. Part# is 24080-N2200 (superseded), some sites show NLA, others show available but at $70 (holy shit must have gold plated ends). Want high quality, stock looking, not the typical two bolts clampdown type. Has to have the additional body ground terminal. Maybe some other later model Datsun/Nissan models might have something that might work. Did some searches, but have come up empty handed.
510wizard
Re: Battery Cable Replacement Options
Postby 510wizard » 09 Apr 2016 13:50
Well, ended up making my own. Did both negative and positive battery leads, added a little length to both. Used "Fusion" brand solder-on terminals and larger wire with triple thickness heat shrink. Ordered the correct right angle end for both positive and negative. I think that they came out great!
Also CAD plated the hold downs, nuts and washers
Image;
Postby two_68_510s » 09 Apr 2016 15:25
DAMN!
qwik510
Postby qwik510 » 09 Apr 2016 18:32
Looks nice.
Enjoy The Ride!
David
510wizard
Postby 510wizard » 10 Apr 2016 07:14
Thanks!
Postby datzenmike » 10 Apr 2016 08:33
Maybe a trip to a wrecking yard could get you a cover for the positive terminal? It could prevent a wrench from being welded to your hold down.
510wizard
Postby 510wizard » 10 Apr 2016 17:33
datzenmike wrote:Maybe a trip to a wrecking yard could get you a cover for the positive terminal? It could prevent a wrench from being welded to your hold down.
Already have the cover on the positive terminal, although a new one would be nice.
Return to “Body & Electrical”
