Mallory dual point distributor
farmer_fred
Post by farmer_fred » 25 Mar 2016 04:19
A friend gave me a Mallory dual point distributor and I wonder what it's designed for. It def fits L-series 4-cyl but appears to have no vacuum or mechanical advance?
Any info would be appreciated.
TIA
Re: Mallory dual point distributor
Post by defdes » 25 Mar 2016 04:25
Those things usually have interchangeable springs underneath the plate under the rotor to adjust the advance, no?
loungin112
Post by loungin112 » 25 Mar 2016 13:55
I'm not sure about the interchangeable springs, but mine adjusts the timing with the inside plate. Mine is not a dual point though. I contacted Mallory a few years back and they noted there is a kit available to go to optical points. Mine is wired through an MSD box.
farmer_fred
Post by farmer_fred » 27 Mar 2016 05:35
I double checked and with a couple shots of 6 in 1, the mechanical advance freed up. So there is a mechanical advance (springs and bob weights) under the points plate.
