68 WIPER ARM NUTS??
datsun5104dr
68 WIPER ARM NUTS??
Postby datsun5104dr » 04 Apr 2016 10:04
I have just about everything for my 68. Motor, bracket, all linkages and arms. Missing the wiper arm nuts. I'm assuming there's another couple nuts to hold the linkage in place where they go through the cowl? Some info on this would be appreciated... Thanks in advance.
-Mike
'68 Datsun 510 4DR
MikeY
Re: 68 WIPER ARM NUTS??
Postby MikeY » 04 Apr 2016 11:36
I don't have any parts for you but here is a picture to show you how the pivot comes thru the cowl. I also have a 411 and it has the same setup. A roaster might also be the same. When looking for 68 parts it's a good idea to check both cars for crossover parts.
Postby RMS » 04 Apr 2016 15:18
yup the roadster has the same pivots , nuts and links.
butters68
Postby butters68 » 05 Apr 2016 00:11
the bottom nut in pic holds the pivot in place.
datsun5104dr
Postby datsun5104dr » 05 Apr 2016 05:39
Is that all I'm missing? Looks like I'm missing a cap as well? Thanks
-Mike
'68 Datsun 510 4DR
MikeY
Postby MikeY » 05 Apr 2016 09:49
Yes your missing the cap and nut. As well as the rubber gasket. Good luck with the hunt. I spent 5 years looking for an ashtray. I love the 68's but they are not easy to own.
dodgydan
Postby dodgydan » 05 Apr 2016 11:47
these are the parts needed
datsun5104dr
Postby datsun5104dr » 05 Apr 2016 12:14
thanks dodgydan!
-Mike
'68 Datsun 510 4DR
datsun5104dr
Postby datsun5104dr » 05 Apr 2016 14:35
I actually went back to my build thread to see if my car ever came with those pieces and it did. Just found them! Everything but the rubber gaskets. Thanks guys.
-Mike
'68 Datsun 510 4DR
Postby Three B's Racing » 06 Apr 2016 05:30
Rubber gaskets should be an easy make Mike. Hey did I point you in the right direction on your brakes? If not you can smack me at Summit Point 8>O
Return to “Body & Electrical”
