Inner door welting trim replacement options
eastbaysolo_73
Postby eastbaysolo_73 » 01 Jun 2016 13:01
Sup fellas,
Was wondering what you guys are you using for the welting trim replacements on the inner door and Rear 1/4 windows. Found these guys in Canada but couldn't find any threads where people have actually used it. Any info will help as my 2 door didn't come with any.
Edge Trims Steel-Core (Flexible, Snaps-On)
Its $2.24 per ft. Canadian
Thanks in advance.
Nor Cal Meng !
qwik510
Re: Inner door trim question
Postby qwik510 » 01 Jun 2016 20:56
I think it's called welting. There has been some for sale on eBay in the past.
Enjoy The Ride!
David
eastbaysolo_73
Postby eastbaysolo_73 » 01 Jun 2016 21:12
Thanks for the info qwik510. I haven't seen any but I will keep a look out on eBay now.
Nor Cal Meng !
510wizard
Re: Inner door welting trim replacement options
Postby 510wizard » 02 Jun 2016 07:35
You might try
http://www.trimlok.com
They have it and are in California.
eastbaysolo_73
Postby eastbaysolo_73 » 02 Jun 2016 15:26
Thanks 510wizard. Are you running it in your car? They have so many option lol. I don't have an original to use for reference so not sure what size I might need to buy. Either way thank you.
Nor Cal Meng !
Postby RMS » 02 Jun 2016 15:50
I have stock 69 2dr trim with metal corners or 70s rubber corner fill I could ship. still soft, a few rubs could look mint with a spray of sem's trim and vinyl in landau black .
eastbaysolo_73
Postby eastbaysolo_73 » 02 Jun 2016 16:26
RMS wrote:I have stock 69 2dr trim with metal corners or 70s rubber corner fill I could ship. still soft, a few rubs could look mint with a spray of sem's trim and vinyl in landau black .
Sent you a PM
Nor Cal Meng !
eastbaysolo_73
Postby eastbaysolo_73 » 03 Jun 2016 10:25
Come on fellas if you have any info on what you used for replacements please chime in. I know there's a few of you out there who's project didn't come with any and would like to know as well. I read some where that some of the guys are using BMW welting for there 2 door 510's as well. Unfortunately I can't find that dam thread after searching for it. Gonna have to dig deeper on the web. But I will find out what year and model is being used and see if I can find some at my local yard for a test fit.
Nor Cal Meng !
510wizard
Postby 510wizard » 03 Jun 2016 12:46
eastbaysolo_73 wrote:Thanks 510wizard. Are you running it in your car? They have so many option lol. I don't have an original to use for reference so not sure what size I might need to buy. Either way thank you.
No I haven't used them on a 510, but have used plenty of their stuff. On their web site, look under build your edge, put in the thickness that you need to go over, then select the leg distance( which is the height). This stuff is very similar to the factory Datsun item. You can request a sample.
http://www.trimlok.com/prod/Build-Your- ... er_87.aspx
eastbaysolo_73
Postby eastbaysolo_73 » 03 Jun 2016 13:29
Sweet thanks man. What I'm trying to do with this post is gather as much information out there and help anyone along the way if I can with it. Thanks for chiming in. Very much appreciated.
Nor Cal Meng !
Return to “Body & Electrical”
