Factory Tachometer Repair
TheHeretic
Postby TheHeretic » 16 Jul 2016 17:13
I have two tachometers (one NOS) and both are not working. One just jumps around a lot and doesn't have a steady reading and the other maxes out once the key is turned to on. I've opened both of them up and noticed nothing broken or disconnected. Even tried resoldering all the connection for the one that jumps around and nothing has helped. I know that Randy York was repairing them using 200SX boards but he is not around anymore (RIP). I might try the attempt myself but would rather pay someone else whose done it several times. Is there anyone who does this on the side?
Carpe Diem!
Ryan
Re: Factory Tachometer Repair
Postby okayfine » 16 Jul 2016 20:12
Jumpy tach may also be a ground issue with your ignition, especially if you're running EI.
If you're already comfortable with soldering on your tachs, the retrofit isn't much more complicated:
DQ Volume 11 Issue 3 - Tech How-To: 510 Factory Tachometer Repair — Updating a previous DQ article using parts still available in most junkyards.
Postby icehouse » 17 Jul 2016 00:01
I would bet some $$ it's not that tach. I've personally never ran across a "broken" factory tach. Yes some slow and off by a few hundred RPM's but not broken aka not able to get them to hold a steady idle. Sounds to me like a wiring issue. If your main power input to the chassis harness is shitty it will make the tach jump around. Check the white wire and make sure the connections are solid. Also clean the fuse box with some vinegar.
For reference we once got a free two door that a tree fell on, it sat in a field for years with no glass. The tach was pulled and installed in another car. It was lagging by 3 but worked! Super funny to rev and watch :)
TheHeretic
Postby TheHeretic » 19 Jul 2016 15:11
Grounded the distributor and even tried the 1k ohm resistor that someone suggested. Wiring looks very good and the fact that both tachs will allow the car to start while responding differently makes me think it's not just the wiring. But going to see if I can ground the NOS tach tonight and see if that makes a difference.
Carpe Diem!
Ryan
Postby funwithmonkeys » 20 Jul 2016 10:15
I fought with the same problem with an aftermarket tach for over a year. I replaced a lot of wires before the problem was found. It turned out to be the mail power wire for the car that hooks to the starter and goes to the fuse box was my problem. A bad crimp connector was all it was. Make sure you check the wires going to your coil also.
Return to “Body & Electrical”
