Bodywork in SF/Bay Area?
awsnap
Post by awsnap » 28 Jul 2016 20:04
Picked up this 2-door 510 in need of some front end repair. Picked up a rad support plus, from Troy Ermish this morning, thanks Troy. Looking for a recommendation for body shop in Nor Cal, Bay Area that might be able to either replace the support or weld in the front clip, or recommendations on which route is best. Thanks!
And the new piece:
Appreciate any suggestions
Re: Bodywork in SF/Bay Area?
Post by RMS » 28 Jul 2016 20:50
if your not having the car completely striped and painted, block the wheels/ tie the car down and give it a yank with the blazer. then dolly out the rest.
Post by okayfine » 29 Jul 2016 05:48
That'll be a million dollars, approximately.
awsnap
Post by awsnap » 29 Jul 2016 07:02
RMS wrote:if your not having the car completely striped and painted, block the wheels/ tie the car down and give it a yank with the blazer. then dolly out the rest.
I totally wish I knew what you were talking about
Post by Three B's Racing » 29 Jul 2016 08:11
Pulling the passengers side out straight, straightening it out. You could pickup a couple cabled comalongs or a hydralic porta power and do that but I'd first remove the front facia. But then that front clip you got from Troy may be easier to adapt.
