Page 1 of 1
Speedo not working anymore
Posted: 09 Aug 2016 10:40
by Doraemon
During removal of the dashboard I unplugged the speedo. But later when I screw the speed cable back in the cluster.. It doesn't work any more ?
I tried to drive slowly and unscrew the cable a bit.. and some how it worked a bit again... but was way off. Hour later it stopped working again.
Is there a special way to plug this cable in the cluster ? Or did I damaged something ? Anyone else recognize the problem ?
Re: Speedo not working anymore
Posted: 09 Aug 2016 15:07
by defdes
It sounds like it's not engaging all of the way, if it's unscrewed can you see it spinning?
Though others here have condemned this move, the edges on the end of my cable were rounded over, I trimmed 1/16" off the end and squared it off with a file and it now works great.
Posted: 14 Aug 2016 03:03
by Doraemon
The cable it self is working. But will have a better look today when I'm at the car. But still not exactly don't know what you mean with edged of the cable rounded over ? Will try to make pictures
Posted: 14 Aug 2016 05:46
by defdes
If the very end of the cable no longer has sharp corners in which to engage into the back of the speedo, it will spin without turning the mechanism.
Posted: 14 Aug 2016 13:34
by Doraemon
Did some cleaning up and removed the grease. And saw what you are meaning. Mine did had some weird kind of square metal shaped wire thing. Found that when to much power applied the wire goes in the cable. Tried to push the cable in the speedo couple of time and sensed when it slips in easy it fitted well. Now it works again. Thanks for the help Defdes
