Is the 240z wiper motor the same as the 510? It looks similar in pics, but I can't seem to find any info.
http://www.thezstore.com/page/TZS/PROD/ ... 02/12-4472
Also, does anyone have any insight regarding where I could get a replacement rubber boot/housing for the motor (where it attaches to the tank)? Mine is dried out and disintegrating.
Thanks!
Washer fluid pump replacement
- DonnieDatsun
Re: Washer fluid pump replacement
looks like the one. ....i may have to grab one for the 68
what no buy it now ? where's my instant gratification...oh well I will gussy up mine, fix the weep.
DonnieDatsun wrote:Is the 240z wiper motor the same as the 510? It looks similar in pics, but I can't seem to find any info.
Thanks!
240Z and 510 bottle assembly is the same.
Enjoy The Ride!
David
David
- DonnieDatsun
Are there any places that sell replacement rubber for the motor mounting point?
It's used on the '60s Nissan Patrol and on the S30 through '73.
Unless trying to be period correct the 620 washer bottle is similar, maybe more rounded and larger, 610s are squarish like the 510 but deeper/longer? S10 similar to the 610s They all say JIDCO so no one will notice.
- DonnieDatsun
I'm definitely trying to keep it correct, but I have a bottle in pristine condition, I just need the rubber boot for the motor.
I can scare you up a washer motor mount rubber thingy. Drop me a note to z240@shaw.ca.
after spending the cash and waiting on delivery I can honestly say NO, no it is not the same!DonnieDatsun wrote:Is the 240z wiper motor the same as the 510? It looks similar in pics, but I can't seem to find any info.
first impression was not good. cheesy flaky patch wire and a tall plug( not correct for 68-73 pl510. luckily I had a washer bottle and rubber boot from an HL510.
dropped the old pump in a cup of hot water to soften up the rubber for extraction.
laid the new pump beside the HL510 pump...ya....still not close to right.
something tells me this won't fit
ready to grab the BFH and start smashing .......took a deep breath and dismantled the damaged HL pump.
pl510 hl510 universal replacement
with a small flat head I bent back the crimp.
with the cap removed I gently bent the tab retaining the impeller extracted impeller and slowly worked the gland up the shaft and out of the barrel exposing the contacts.
I cleaned up the commutator and winding. then used a insulating clear lacquer on the winding's
I then took apart the pl pump and destroyed one of the contacts removing the gland....so much for making a new pl pump
where's that hammer ...............
