identification of nuts and bolts
dat5102dr
Postby dat5102dr » 05 Nov 2016 23:42
Looking for a example of the nuts and bolts used for door hinges, hood and trunk
thanks for your time
dat5102dr
Re: identification of nuts and bolts
Postby dat5102dr » 07 Nov 2016 14:05
Postby RMS » 07 Nov 2016 15:12
hinge to body are the same as trunk to hinge fillips with captured lock and flat washerImage
door to hinge are the 2 middle cards full of bolts with a raised #4
hope this helps. more on bolts in my build thread http://www.the510realm.com/viewtopic.php?f=27&t=26416&start=180
dat5102dr
Postby dat5102dr » 07 Nov 2016 15:31
thanks
the hinge to frame is a nut and bolt
that I can't seem to find in my bucket
I count 10 total
and still can't find a match
but I did find this picture
Image[/URL]
MikeY
Postby MikeY » 07 Nov 2016 15:34
On the left (m 8x1.25) is door hinge to body and trunk hinge to trunk lid. Middle (m8x1.25) is hinge to door. And on the right , (m6x 1) is hood , both hinge to body and hood. As well as fender to body.
MikeY
Postby MikeY » 07 Nov 2016 15:37
Someone has messed with those hinges. The hinge is threaded for a bolt at the hinge to body.
dat5102dr
Postby dat5102dr » 07 Nov 2016 16:17
oops
my mistake your right
so hinge to door ( the middle one)
is just screwed into the door ??
and the bolt to frame uses a nut
Postby RMS » 07 Nov 2016 17:15
no nuts required on a pl510, hinge has threads doors have captured nuts .......looking at your pic thats not a pl510 or at least any door pillar I have seen.
dat5102dr
Postby dat5102dr » 07 Nov 2016 17:17
thats just a reference not my car
sorry for the confusion
The Taterhead
Postby The Taterhead » 08 Nov 2016 07:48
Looks like a 710 (the orange car)
dat5102dr
Postby dat5102dr » 17 Nov 2016 12:50
I found a picture of the bolts used for the gas door
Image[/url]
dat5102dr
Postby dat5102dr » 17 Nov 2016 12:53
anybody have a picture of the 1/4 window screws? (screw hinge to frame)
and also need the set up
for the hood latch?
thanks
Return to “Body & Electrical”
