Wiper motor issues!
BackPackSaddler
Wiper motor issues!
Post by BackPackSaddler » 31 Mar 2017 15:29
Since I bought my 72 510 a month ago the wipers haven't worked, Did some poking around with my test light today and found that there is no power going to the wiper motor itself, and also no power to the switch at inside at all. But on the fuse box there is power at the wiper fuse, I'm kinda stumped here, everything is plugged up as it should be so idk what the issue is here, and suggestions would be awesome!
Re: Wiper motor issues!
Post by icehouse » 31 Mar 2017 15:31
Blue with red stripe wire that goes to the wiper motor should have power.
BackPackSaddler
Post by BackPackSaddler » 31 Mar 2017 15:52
Has no power..this is what's got me puzzled. With key on there is no power on that wire at the motor plug, or the switch inside, however there is power going through the fuse in the fuse box. Also there are two red and blue wires coming out of the plug at the fuse box. Not sure if there should be one of two there .
Post by okayfine » 02 Apr 2017 19:18
Wire broken between the fuse box and the motor? Bad fuse (may look good, but detached inside the cap, have had it happen so BTDT). Take your year/style of fuse box and look up the DQ backissue that has the wiring diagram.
Once you get it all sorted, add a better ground to the motor.
BackPackSaddler
Post by BackPackSaddler » 03 Apr 2017 14:42
Thanks okayfine! I'll check the fuse, I've got a bunch of new ones so I can go ahead and put a new one in it. I'm leaning towards a wire broken somewhere between the fuse box and motor and or switch inside.
