stock 510 tach hooking up to MSD 6 ignition
tcflacars
Post by tcflacars » 11 Apr 2017 08:37
Trying to figure out how to hook up my 510 stock tach to MSD 6 ignition
510wizard
Re: stock 510 tach hooking up to MSD 6 ignition
Post by 510wizard » 12 Apr 2017 07:19
If I remember right, I think that MSD makes a module/adapter for this, call them.
Post by okayfine » 13 Apr 2017 17:45
DQ Volume 3 Issue 2 - Tech Q&A - Have you installed a MSD ignition black box and can't get your stock tach to work? If you're using a magnetic trigger distributor, like the factory Nissan unit from the late '70s, the addition of the correct MSD tach adapter can get your tach working again.
