upgrade alternator
510Wagon71
upgrade alternator
Postby 510Wagon71 » 12 Nov 2017 04:12
Hi.
Im considering to upgrade my alternator to a IR type that delivers more AMP.
I have read about the wireing that needs to be changed, and it sounds like its easy enough..
BUT, i have asked and looked around in the nearby junkyards and cant find a alternator that fits, so it seems that i have to buy online.
And then i want to be sure that i buy one that fits and delivers enough AMP. (maybe 70ish)
Im after a alternator that is bolt on besides the wireing.
What alternator should i go for?
Is a Hitachi-LR160 a good option ?
Anyone know a part number or a place that i can buy one that is bolt on?
Re: upgrade alternator
Postby datzenmike » 12 Nov 2017 20:13
LR 160 is only 60 amp while the stock 510 was 33/35. Most later Datsuns into the mid '80s were 50/60 amp. These will just bolt on no changes.
The one wire Saturn alternator also bolts on. May have to modify the adjusting strap.
The Hardbody alternators retained the V pulley into the mid '90s. They are 80 or 90 amp. for a stable supply for the EFI. I have a 240sx KA alt on my L18 in my 710 sedan. Had to swap the V pulley onto it and splice in the two wire connector for the sense and charge lamp.
Postby RMS » 14 Nov 2017 13:54
if your in the junk yard check out the subaru dl dg loyal and early legacy for the 60 to 120amp hitatchi and dont forget to take the T plug.
Postby defdes » 16 Nov 2017 16:18
The wagons didn't have IR alternators though, correct?
So you will have to bypass the voltage regulator.
Postby RMS » 16 Nov 2017 18:48
all my dl gl and loyals had ir alts ?
510Wagon71
Postby 510Wagon71 » 26 Nov 2017 04:12
The junkjard is not an option since my lokal yard does not have anything that fits.
I have to buy a new one and i live in Norway, not easy to find parts here ..
Mike: Does the LR160 bolt straight in, is it a good option or would you reccomend another one ?
https://en.as-pl.com/c/all/lr160
This page got a list of different LR160 alternators, do you know which one fits the 510 ?
510Wagon71
Postby 510Wagon71 » 15 Jan 2018 12:06
Just a short update.
I bought a alternator that is used in many newer nissans like primera, almera, x-trail
It fitted straight in with NO modifications at all, i just had to rewire to get rid of the external volt regulator.
The nissan part number is 23100AD210 and its a 110amp alternator.
Postby datzenmike » 16 Jan 2018 06:24
All Datsun/Nissans switched to internal regulator for the '78 model year. They also switched to EI ignition.
Ford Quest and Mercury Villager alternators (yes some Fords used Nissan VG engines)
93-98 - v40 = VG30E = 1 sliding door made in TN = Mitsubishi 110 amp
99-03 - v41 = VG33E = 2 sliding doors made in TN = Mitsubishi 125 amp
04-10 - v42 = VQ35DE = 2 sliding doors made in Canton MS = Valeo 130 is actually a 145 amp
Return to “Body & Electrical”
Users browsing this forum: No registered users and 5 guests
