New from JAPAN
Users must be approved by our moderation team before posting in other forums.
JP2400
New from JAPAN
Postby JP2400 » 19 Jul 2017 10:12
New from Yokohama Japan!
1972 510 swapping Honda K24A with S2K 6 speed :D
Re: New from JAPAN
Postby two_68_510s » 19 Jul 2017 12:10
Hi! is that engine normally longitudinal? Very clean installation, how much HP? Welcome.
Re: New from JAPAN
Postby 510rob » 19 Jul 2017 13:46
JP2400
Re: New from JAPAN
Postby JP2400 » 19 Jul 2017 18:09
Hello, Thank you for your comments.
This engine is normally latitude, so required custom fitting parts to utilize S2K manual transmission. Those can be purchased in the US. Japanese tuning shop, S&A autocreate , installed it very nicely.
The HP could be approx. 200HP as K24A2 stock for Odyssey absolute. Not so much power, but enough torque for easy drive:)
Re: New from JAPAN
Postby 510rob » 20 Jul 2017 01:34
Beautiful car. Welcome to the site. I noticed that your car is left hand drive as well. Is that rare to see in Japan?
JP2400
Re: New from JAPAN
Postby JP2400 » 20 Jul 2017 02:56
Thank you very much:) Yes, it is! But nobody realize it on the street except enthusiasts.
Born in Yokohama, 1972
Raised in Beverly Hills, 1972-1997
Customed in Yokohama, 2017
She is a frequent flyer:)
PoorMtnKid
Re: New from JAPAN
Postby PoorMtnKid » 20 Jul 2017 16:48
Awesome swap! I was looking into this for a while after I seen a Miata had one it it. I couldnt come to make the change from my SR based on the costs. Very cool to see.
JP2400
Re: New from JAPAN
Postby JP2400 » 20 Jul 2017 20:13
Thank you! Could be the first swap on 510. Actually, I planned SR20 swap at the beginning, but it was difficult to find a good one in Japanese junk yard. Thanks to Miyata or S2K swappers, K24A2 is becoming a feasible option now:) Much cheaper than F20C on S2K and many tuned parts are available in the market! My 510 is a kind of proto-swap with K24A, so I'm looking forward to seeing more insane Datun in the near future.
McShagger510
Re: New from JAPAN
Postby McShagger510 » 20 Jul 2017 20:46
Interesting swap fo sho! Welcome to the site.
'91 Nissan truck
JP2400
Re: New from JAPAN
Postby JP2400 » 21 Jul 2017 04:29
Thank you, James! New challenge is always exiting as you know:)
duke
Re: New from JAPAN
Postby duke » 29 Jul 2017 10:26
Welcome! Very cool swap. You have got me contemplating. Do you have any pictures of the underside of the car? I would like to see what you did for the oil pan and stuff. Do you know how much weight was added with this engine?
JP2400
Re: New from JAPAN
Postby JP2400 » 01 Aug 2017 07:50
Thank you, Duke!
Unfortunately, I don't have a clear pic of the under floor. The shop, S&A auto create in Japan, did really good work on oil pan and crossmember to avoid travel range of steering link.
As for added weight, I have not measured it, but I found some numbers on the web as shown below... Significant increase!! :shock:
L16: 260lbs
K24A2: 413lbs
Diff: 153lbs
KiKiIchiBan
Re: New from JAPAN
Postby KiKiIchiBan » 02 Aug 2017 05:22
Very nice looking car.
My Bluebird SSS Coupe #25
JP2400
Re: New from JAPAN
Postby JP2400 » 02 Aug 2017 07:23
Thank you!
Your racing car also looks very cool with Refresh 60 decal:) I live in Yokohama, and near Refresh 60. Very sadly, it will be closed within this year :(
Return to “Introductions”
