Steering box seals
skippyelwell
Steering box seals
Post by skippyelwell » 30 Jul 2020 17:55
The lower seal on the pinion shaft of my steering box was shot so I tore it all down, measured and found the exact seals at https://www.avxseals.com/
Hope this helps someone out. Does anyone know what weight of gear oil I should use in the box?
The attachment IMG_0179 (1024x768).jpg is no longer available
The attachment IMG_0180 (1024x768).jpg is no longer available
The attachment IMG_0181 (1024x768).jpg is no longer available
The attachment IMG_0182 (1024x768).jpg is no longer available
IMG_0179 (1024x768).jpg (356.88 KiB) Viewed 190 times
skippyelwell
Re: Steering box seals
Post by skippyelwell » 30 Jul 2020 18:01
IMG_0180 (1024x768).jpg (293.96 KiB) Viewed 188 times
IMG_0181 (1024x768).jpg (316.86 KiB) Viewed 188 times
IMG_0182 (1024x768).jpg (430.58 KiB) Viewed 188 times
IMG_0184 (1024x768).jpg (396.25 KiB) Viewed 188 times
Post by bertvorgon » 30 Jul 2020 18:33
