Hi
My name is Anthony and i'm from the UK (my web site http://www.datsuns.co.uk), while looking for some parts and advice on the web i came across this site, Maybe someone on here can help (i hope )
I'm in the process of doing a VG30E conversion to one of my Datsuns i was really luck in getting a plenum and headers from the US but sadly there is a few pipes i need to finish the job and i'm having no luck getting them
If some one is willing to try and help a desperate guy out i would be great full
Thanks
Anthony
Hello
I would help u but sadly in quebec eveyrthing is CRUSHED sooo fast but here you are maybe this will be good to you
http://www.car-parts.com
Have fun bud and keep us updated on your car
man i can't belive the response wish i had found you site before, I know a guy in Ausy that can still get 1600 parts he might be able to help you get a grill etc and might even be able to get new ones if you want to try. 510 in the uk think there is about 5 or so
the pipes i'm looking for a maily air pipes and one water pipe, and a really hard one is a tach from a G810 (think in US it's called a maxima)
here is a couple of pics of the pipes i need.
the pipes i need are
1 cam cover breather pipes to plenum and air intake
2 air pipe from (lh side) idle control valve that joins air regulator then goes round rear of plenum and joins air intake
3 water pipe from lh side plenum round rear and joins thottle body.
i have pictures of a plenum complete i can post them if that helps
here is a picure of the install, it's not been clean or anything yet, and we only got it running the other day, but it's running crap at the moment
I also have a Datsun with a FJ20ET in too If you want to see them go to my site http://www.datsuns.co.uk and look under our cars
