68 dash pad
68 dash pad
ok just wundering, do i have to take my hole dash apart to get my dash pad of,or just take the 4 screws from the ends of and lift ,ive never had this still dash before.
Re: 68 dash pad
It has to come apart. The lip of the dash bolts through the dash frame.
Re: 68 dash pad
dang, man that sucks .thank you mr okayfine.
- two_68_510s
Re: 68 dash pad
Hi
Here are some photos inside a spare dash I have.
I don't see the pad coming off this superstructure it seems to have been molded together.
I have more pictures if you need them this is an unrestored '68 dash
Re: 68 dash pad
Can you take pictures of the inside of the dash structure along the top-front (along the top-inside of the gauge panel, for instance)?two_68_510s wrote:Here are some photos inside a spare dash I have.
- two_68_510s
Re: 68 dash pad
Ask and ye shall receive!
Re: 68 dash pad
Awesome. Shows some of the nuts you'll have to remove to pull the pad off. Lots more than just the two on each side. Welcome to early-dash ownership. '69s are similar. Late/plastic dashes are much more modular.
- two_68_510s
Re: 68 dash pad
I have been looking this dash over, it may come apart, but I think the entire dashboard structure has to come out of the car.
The main steel frame that goes up under the "vent grill" at the windshield is molded into the pad and is wrapped around, take this end of the dash as a case in point, three views: All in one piece on the outside that wraps all around 3D, BUT is bolted to the main frame. The caveat is you seem to have to remove the whole frame from the car to get it off
Re: 68 dash pad
maybe i will pass on that ,i was just try'n to get the dash pad out to put on a new dash cap,the kind you glue on .
- two_68_510s
Re: 68 dash pad
I just put one in my 620 without taking it out. (looks a lot better BTW)
Just use lots of bracing to squeeze the edges down all over evenly. I had dowels and sticks going in all directions because that one has pieces that come down the front of dash, I don't think yours would be that hard.
Re: 68 dash pad
Butters, did you geta US style dash cap - with the dip in the middle?butters68 wrote:maybe i will pass on that ,i was just try'n to get the dash pad out to put on a new dash cap,the kind you glue on .
Re: 68 dash pad
yes i did byron, it will be up for sale shortly,i just need to take some pics of it.
ya it doesnt fit right.. i got my dash all apart and i m cleaning the left over sand from sandblasting ,fun times.
Re: 68 dash pad
two_68_510s ,thanks for the pics of your dash pad it help,got my dash all apart.
- two_68_510s
Re: 68 dash pad
Your are welcome, my pixels are your pixels!
