http://www.worldcarfans.com/11401276933 ... rbo-engine
http://nissannews.com/en-US/nissan/usa/ ... powerplant
http://www.foxnews.com/leisure/2014/01/ ... p=trending
New Nissan engine - 3 cylinder 400HP
- Contact:
Re: New Nissan engine - 3 cylinder 400HP
I hate odd number cylinder engines. Seems off to me. Pretty impressive though
'69 2dr KA24DET
IDx, stat!
Wow, that packaging looks impressively small. I'm thinking you could slap a couple of those bad boys end-to-end for a relatively petite straight 6.
-McWicked
-McWicked
I really had to get used to odd numbered cylinders when I started in the shipping industry. All of the bigger bore engines are online, but you get all combos, 3,5,6,7,9,11 - everything except 4. I have been told that 4 cylinders don't work well due to vibration. Wartsila does make a 4 cylinder 60 bore engine, but still put a 5th throw on the crank with a mock piston to curb vibrations. So if this is a problem on larger diesels, than at some point it's likely a problem in our "little" engines too.finn wrote:I hate odd number cylinder engines. Seems off to me. Pretty impressive though
Just my thoughts on odd number cylindered engines.
- Contact:
I think you hit it Byron, they were going for the maximum output per cc and balance is required for that. It must be a more balanced package.Byron510 wrote:I really had to get used to odd numbered cylinders when I started in the shipping industry. All of the bigger bore engines are online, but you get all combos, 3,5,6,7,9,11 - everything except 4. I have been told that 4 cylinders don't work well due to vibration. Wartsila does make a 4 cylinder 60 bore engine, but still put a 5th throw on the crank with a mock piston to curb vibrations. So if this is a problem on larger diesels, than at some point it's likely a problem in our "little" engines too.finn wrote:I hate odd number cylinder engines. Seems off to me. Pretty impressive though
My subaru domingo has a 1.2L 3 cylinder engine, revs up pretty good too! My old suzuki had a .657 3 cylinder turbo engine and that little guy just screamed all the way to 7K ...
