Fuel Pump Question
timmer510
Fuel Pump Question
Post by timmer510 » 30 Sep 2015 07:36
Fuel Pump Question.
Hey does anyone know if the L-Series Mechanical Fuel pump for the 6cyl will work on the 510 4cyl ?
Thanks
Tim
Re: Fuel Pump Question
Post by RMS » 30 Sep 2015 07:58
yup thats what I will be running with dual webbers
zKars
Post by zKars » 30 Sep 2015 10:00
No fitty. Two bolts vs three. MAybe the arm that touches the cam lobe is the dah same, but not sure it will bolt on.
AirTex 1069 vs Airtex 1080 for part numbers at rockauto...
Wait, I have a 510 head here and Z pumps... I check....
Post by okayfine » 30 Sep 2015 10:08
Tim, if you're looking for a larger-than-stock-510 mech fuel pump, the pumps for L20B will fit and are larger than 510, so will push more volume. I posted a Carter-boxed screw-top pump recently in another thread, available from RA.
zKars
Post by zKars » 30 Sep 2015 15:20
The Z pump "fits" on the two studs, but there is a small gap left at the top of the head hole, just above the pump body. Maybe the gasket/insulator will cover it. Looks like it might work IF the actuator arm is same. I don't have a 510 pump handy to compare. Best go with okayfines solution.
Let me also share a recent discussion about rebuilding Z pumps. I believe this applies to the current situation and also sheds light on how many of the early Datsun's fuel pumps share common components.
http://www.classiczcars.com/topic/50679 ... fuel-pump/
Butts
Post by Butts » 01 Oct 2015 13:53
I had a bad experience with a Spectre Premium pump, which is very similar to the Airtex pumps at Autozone, RockAuto etc. I'd stay away from them. I'm getting a Carter pump per Okayfine's recommendation for a few bucks more, the engineering is much closer to the OEM pump.
Doctor510
Post by Doctor510 » 16 Oct 2015 11:20
The Z (6 cyl) pump and the 510 share the same diaphragm, doesn't fit well and offers no advantage for performance. Want performance? Go low pressure electric.
