what valve spring compressor should I buy ?
Post by RMS » 21 Sep 2016 15:03
this:Image
http://www.ebay.co.uk/itm/Midlock-On-Ca ... 0153769732
or
this:Image
http://www.ebay.com/itm/Sealey-Valve-Sp ... 1597079803
any other options known ? lordco could not help
Re: what valve spring compressor should I buy ?
Post by okayfine » 21 Sep 2016 18:02
The second one has an adjustable angle for the handle. I made my own and originally had a straight handle. When I tried to use it I found I ran out of room to depress the handle without it being angled up.
Post by RMS » 21 Sep 2016 19:00
did you use a hole saw to make the hooks ?
Post by okayfine » 22 Sep 2016 05:52
I don't remember. It doesn't look like I did, but I definitely should have. That part wasn't a problem, but I also believe I eventually cut a notch into the compressor piece similar to the notched replacement arm on the top version in your OP. Been a while since I used it, so details escape me.
datsun510
Post by datsun510 » 29 Sep 2016 22:12
I use the factory valve spring compressor that was available from Datsun Comp many years ago.
Post by okayfine » 01 Oct 2016 06:21
Looks like the factory tool has a much longer spring compressor piece, which would mitigate my angle issues. OP's top compressor choice with the spring compressor piece mounted in the tallest config might replicate the OE positioning.
