SR20DE Swap: Electrical
I recently bought a 72 2-door with an SR swap in progress. It came with a KA harness and computer. I could probably do the wiring myself but I've never been all that confident about working on that stuff. Is it just a matter of matching the pin-out of the ECU to the right sensors/injectors/ignitor/etc. or am I headed for trouble? If I could find someone near here (Oxnard, CA) that does that kind of work at a reasonable price I'd just use them but so far I haven't found anyone.
Wow is this some sort of hipo upgrade, SR20 with KA computer. I wouldn't touch it with a stick. I would recomend getting and SR20 ECU and harness
Corky Bell, Maximum Boost
-defdes
-defdes
spriso_silvia@yahoo.com <- that guy makes a plug and play harness out of your KA wiring
Jim Wolf Tech will reprogram your ecu to run the SR
- RWD_NissanMan
The KA ECU is quite different from the SR20 ECU (unless you have the "non-turbo" version of the SR20 that uses a distributor rather than a CAS. The SR20DET ECU supports "coil-on-plug" and you would have to convert the engine (which I have seen people do with aftermarket components).
Do you have an SR20DE or SR20DET??
you will not beable to use that KA with the SR20. you could use the one off a CA18. you have 3 options
1 go and buy a SR harness/ecu
2 buy a standalone (recomended) http://www.sdsefi.com/
3 buy my CA18DET harness ECU for $500
sorry it sounds like you got the shaft on that one
