Project 635 - 300HP RWD 620
DADZSUN
Re: Project 635x - 300HP AWD Datsun
Post by DADZSUN » 24 May 2020 06:18
Byron510 wrote:
28 Apr 2020 06:36
Fritz, thanks for posting specifically to my request - much appreciated.
I’m trying to get properly oriented in the photos - it was tough at first to even get there. Still the securing of the diff to the block below the skirt is eluding me.
Hi Byron,
Here's a couple more pics with the AC compressor and alternator out of the way.
The differential appears to be between #1 and #2 cylinders. I've since removed the F160 (see next posting for more details) and the VQ35DE AWD block has a hollow upper oil pan that allows the driver side axle 'stub' to feed right to a carrier bearing on the first pic.
'72 Datsun 510 - MS KA24e, Watanabes, STI R180 w/CV axles, R&P assisted steering
'76 Datsun 280z - 2021 Datsun Restomods R&D project
DADZSUN
Slight build rename and update
Post by DADZSUN » 24 May 2020 06:50
Enough good things have happened that it's time for an update!
I've been plugging away on this steady, mostly focusing on front suspension placement & reinforcement. I managed to get the front shock towers identical to G35 stock 13 degree castor. The control arm (ie: TC bushing placement) is also near to stock. This took quite a bit of time to locate and fab.
The VQ35de was cleaned up and some new bits added, including an alternator, starter, and lightened pulley. I have a plenum spacer that I'll wait until after start-up to install. I plan to get an UpRev tune to hit 300hp and more responsive driveability.
I managed to grab the VQ/Auto tranny and diff/transfer case weight (709lbs).
... and did a quick early test fit. The rear frame bracing obviously had to still be cut at that point but it gave us an idea on engine placement for axle operation and firewall location.
It became clear that although the VQ could fit in the 620 engine bay, either:
  • The engine would have to be placed far enough back to allow for proper front axle alignment and thus the firewall would need a large portion removed to recess the block, or
  • Ditch the AWD plan, move the block forward and save the firewall
In the interest of getting this done quick (driving by fall?) and simplify the install, I called and audible and decided on option #2.
It just so happened that I have a CD009 in the garage originally allocated for the 280z build that I 'borrowed' for 635. RWD will save approx 200lbs, not require any kind of auto shifter mounting and control module for operation, and permit obnoxious burnouts. I will be retaining the G35 wheelspeed sensor feeds and traction control to keep some civility when driving.
The beefy CD009 did require from relief around the tunnel, I plan to use the G35 donor car tunnel to fill this in.
End result, we've got a fit! Firewall stays intact, there's still a clear path to the steering rack, and room to run the exhaust. Honestly, this is about as good as it can get for a swap this ambitous.
The hood even closes with a couple of inches to spare - that's with the entire VQ block above the sway bar and cross member, no recessing.
Next up, I'll be working on the cab. Replace the two rocker arms, and source the G35 tunnel and floor pan to graft into the cab. My son will be pulling the G35's rear subframe and gas tank in anticipation for June work.
Even though I'll loose AWD and winter driving (not really, I plan to drive when there's no snow and rely on TC), I'm really stoked about RWD fun. The truck will still be able to haul stuff and a rack/roof top tent is still feasible.
DADZSUN
More updates
Post by DADZSUN » 05 Jun 2020 18:24
I've been hammering hard on this truck, the goal is to start it up this September.
Since the last update I've replaced both rocker panels and inner skin. A ton of other little pieces were also replaced. In the pic below I had to rebuild the front arch rib and lower A pillar. There's still a missing tunnel and driver floor pan but I want to wait until the cab is back down on the frame to push that footwell as deep as possible for more leg room. Passenger-side floor pan is done and cab mounting points have been reinforced on all 3 completed corners.
I seem to be exceptionally talented at finding the hard way to do a swap. It started with a KAe Truck block with S13 intake and transmission. With my decision to go from AWD to RWD on this project there were a 'few' changes required.
The big difference was the upper oil pan. Using a RWD pan would 1) allow the starter to properly clear the CD009 6 speed, 2) align the oil filter to the side, 3) create more room in the middle of the pan to sink the block further down.
Yep, after chatting with Andrew I decided to move the engine back 5" and down 4". The firewall will now definitely has to be cut (approx 5" recess) but the improved handling should be worth it.
Here's how it sits now.
Swapping to RWD mounts further allows the block to be lowered.
Swapping upper pan was a PITA but fairly straightforward. The windage tray on the AWD was part of the pan and not on the block's craddle per the RWD setup. Thankfully there were holes to simply migrate it over.
Ever wonder how much oil is max? Right at the windage tray it seems.
Why not use the spare RWD block I had on hand? Because my suspicions during the $300 purchased were confirmed, LOTS of shavings in the oil pan. No biggie, I really only planned to use it as a jig and scavenging the parts has already saved me the purchase price. I do plan to dive a bit deeper into the block and see if it's just a quick bearing replacement to fix up.
I'm starting to get a more accurate idea of the VQ/CD combined weight, approx 525lbs w/o oil. I will weigh the stock L20 soon to get an idea on the weight change.
This weekend I hope to complete the engine and tranny mounts and start on the exhaust. Afterwards I'll pull the engine and finish up the engine bay with more reinforcements/seam seal/paint. Next, the firewall will get notched and the cab will get patched up for good.
Lots of work, but also LOTS of fun!
Re: Project 635 - 300HP RWD Datsun
Post by Byron510 » 06 Jun 2020 07:33
I was about to ask - if the motor went backwards, why not retain the AWD...
But then I realized that you were likely able to drop the motor down and backwards because the diff and oil pan were changed.
Great progress.
Since you have both the AWD system and the CD09 trans on hand, does it look like the AWD transfer case would mount to the CD09? You know where I’m going with this, but I’m curious if the rear housing on the both box’s might look interchangeable.
Anyways, great to see an ambitious project like this. Please do keep us posted.
DADZSUN
Post by DADZSUN » 11 Jul 2020 15:07
Byron510 wrote:
06 Jun 2020 07:33
... does it look like the AWD transfer case would mount to the CD09?
Hi Byron, unfortunately the G35 transfer case is integrated into the rear of the automatic transmission.
Even if an external, 'separate', unit was sourced, using the AWD upper oil pan to allow room for the driver-side front axle to clear the block will not mount up to the CD009 manual transmission. For some reason Nissan chose to use a different bellhousing pattern between the manual and auto transmissions.
In hindsight the AWD engine/tranny/transfer case combo would 'fit' (relative term here) into my 620 but I'm still happy with the idea of -300lbs off the front and a rowdy Nissan version of an El Camino.
300hp in a 2700-2800lbs pickup will be a challenge but I plan to develop my own traction control system using the g35's wheelspeed sensors, install 245/45R17 tires on 17x8 Subaru STI wheelset, and Wavetrac Torsen-based differential to put effective use to all that power.
DADZSUN
July update
Post by DADZSUN » 11 Jul 2020 15:39
Project 635 is still plugging along nicely. It's a crap-load of work, but it's fun work.
The front two engine mounts are complete as is the transmission mount.
I completed the exhaust routing from the stock manifolds to under the cab (to ensure floor pan clearance). I'm using 2" exhaust per bank, each has a high flow cat complete with Vband mounts. The two banks will likely join soon after the tranny mount using the improved G35 'highflow' Y pipe, and continuing with 2.5" to the tailpipe. The exhaust had to be carefully constructed off the manifold to ensure it came down hard enough to clear the deeper footwell I engineered into the frame and cab.
The front of the frame is now pretty much structurally complete. Once the rear is done I'll remove the body and powertrain and set the frame on its side to close holes, weld, seam seal, then paint.
Once the frame was complete I cut the cab's firewall to clear the recessed VQ. It fits pretty good all things considered, the intake plenum's elbow is just below the upper cowl. It should be reasonably easy to close in, I'm not yet sure what the impact is yet to the heater box...
With the cab in place I began to work on driver-side control fitment. I've got a set of nice '99 Miata seats to use, they're light, comfy, and minimal size - especially in the backrest.
For steering I managed to source an electric steering column that works with the stock G35 steering shaft and UJoint, BONUS! Steering is now done and the assist helps a ton! Steering wheel is a little closer to dash than stock to have a more comfortable reach.
I installed the driver floor pan and will complete the firewall once the pedal box assembly (likely Tilton) is installed. With the deeper firewall and lowered floor pan I managed to gain 3" of much needed leg room.
While I wait for the pedal box, today I started on the rear. Once again my rusty G35x fought me, and one of the main mounting bolts snapped. I'm not sure where I can source another, it's got a taper up top to help centre the rear subframe.
Rear subframe is 286lb if anyone is curious. The mounting point measurement appear that they will play nicely with the 620 rear frame rails. I should have a much better idea on my next update.
Going forward, I'll remove the stock G35 fuel tank along with the EVAP and returnless fuel system. I'll remove the 620 bed and start the alignment/fitment with the G35 rear subframe.
I'm still confident that I'll be able to at least fire up the truck by mid-Sep.
greenthumb
Post by greenthumb » 12 Jul 2020 06:27
Love the updates! So much ingenuity going on here. The shifter for that CD009 is set pretty far back. With the engine being recessed into the firewall, where does your shifter location end up relative to your seating position?
DADZSUN
Post by DADZSUN » 12 Jul 2020 07:18
greenthumb wrote:
12 Jul 2020 06:27
I'm considering two options.
Serial Nine has a sweet solution and is Canadian as well. They appear to also have the shortest traditional rear-mount setup.
Even shorter, and frankly a bit better placement with my existing setup,is the Autosport Engineering setup. This is a LOT more involved setup requiring permanent changes.
I'll likely go with Serial Nine and engineer a custom higher (forward) offset shifter if required. I do plan on implementing a few more tricks to get that driver's seat further back which would bring the Serial Nine placement back into play.
Fritz
DADZSUN
2nd July update
Post by DADZSUN » 16 Jul 2020 14:44
I made some substantial progress on 635 so I figured I'd post an update before forgetting some of the details.
The G35 is finally gone giving me more room to reorganize the build. I've got a 20'x40' garage but with 3 Datsuns, 2 of which are in project phase, and a 3rd (510) trying it's hardest to remain an on-going project, room is lacking - and the missus' is keen to get her winter parking spot back!
The bed and rear axle/brake/suspension came off 620 fairly easily.
Weights were surprisingly similar with only +30lbs added to 635 with the G35 equivalent bits.
The G35 rear slid under the 620 frame easily enough. Once I get new frame mounting bolts machined I'll be able to fairly easily complete the installation. This is looking to be a very viable swap option for 620 owners looking for an affordable IRS or LSD or disc or 5x114.3 swap.
I'm looking to mount a simple coilover off the spring perch location, or fab up a new mount to replace it (maybe with some adjustability). The top of the damper is only a couple of inches above the frame rail, and since it's now located in the stock wheel arch location (5-6" of headroom), the bed will not have to be modified to house the coilover. 8)
A cheap eBay strut tower bar arrived today. It's got to be a good sign when it bolts right up and fitment is exactly within the middle of available adjustment. There's 2" of clearance confirming the engine is in fact a bit lower than stock setup.
... and that's about as far as I can go without more parts arriving. The G35 fuel tank doesn't have a chance of fitting so I'll need a new universal fuel tank (or Pathfinder unit to play nicely with the VQ returnless system). I can't fasten the rear subframe until the mounting studs are machined. I can't dive into rear suspension until the rear is fastened and available clearance is 100% confirmed. I can't complete the firewall until the Tilton pedal box assembly arrives, ditto with the shifter and the tunnel and seat placement.
It's the first time in months (a year?) that I don't have large outstanding tasks to complete. So I'm looking at smaller cosmetic changes that I know will chew some time. Likely first up is the dash, I've begun filling its cracks with epoxy. I'm going to move to flexible body putty for the final finish but first I think I'm going to first take 1.5" out of the depth (right across) to effectively lengthen the steering's reach. A pretty radical modification for a small change but worth it at this stage IMO. Also, I do plan to remove ~10" out of the rear of the bed to give a more symmetrical look to the cab while retaining the long wheel base.
Edm620
Re: Project 635 - 300HP RWD 620
Post by Edm620 » 27 Jul 2020 14:35
"The G35 rear slid under the 620 frame easily enough. Once I get new frame mounting bolts machined I'll be able to fairly easily complete the installation. This is looking to be a very viable swap option for 620 owners looking for an affordable IRS or LSD or disc or 5x114.3 swap."
I like how clean the G35 rear fits under the frame, I've had thoughts about IRS...
Ugandan Proverb
DADZSUN
Nissan Frame studs
Post by DADZSUN » 29 Jul 2020 18:46
Edm620 wrote:
27 Jul 2020 14:35
...I like how clean the G35 rear fits under the frame, I've had thoughts about IRS...
Nice segue for a quick update. My newly machined 4140 M14 Nissan-spec'd frame studs arrived today.
I only need 4, and 12 were made so I have two extra 'sets' of mounting studs for anyone who's interested.
DADZSUN
G35 rear subframe is on
Post by DADZSUN » 03 Aug 2020 14:46
Another update. Seems like the tedious stuff is almost behind and progess appears quicker, at least more tangible improvements.
I managed to get initial supports welded onto the G35x rear subframe. Decided to roll it out into daylight for the first time in nearly a year to see how she sits. The rear will get a more bracing and cleaned up this week.
Pinion angle is looking good. The transmission is angled 1 degree down from horizontal (and adjustable via the mount design), and the diff is 2 degrees up from horizontal. Driveshaft will be ordered this week and once installed, the exhaust can be complete.
The G35 rear subframe sits beautifully in the 620 frame rails. Front mounts are dead centre under the rails and the rear mounts are about 1.5" inboard. There lots of room for suspension articulation. There's even enough room behind the subframe and in between the 620 crossbeams to house a couple Tesla S 5.3 KWH batteries... :shock: 8)
ZFever hacked OEM VQ35DE ECU, and modified harness is done and being shipped back up north. I've got to get the fuel tank sorted out to fire up the VQ hopefully in the next few weeks. Suspension will also be ordered soon.
Post by Byron510 » 09 Aug 2020 08:12
The project is really great to follow, thanks for keeping us up to date with all the details - great stuff.
Regarding the subframe studs, will you also threat the other end and bolt to the (modified or fabricated) frame of the truck as per OEM?
Love the progress, looking forward to following further.
