Hidden for now
Re: Indy's '75 KA710 goon
This is still just base coat ... ........
Bling bling!
got to make the compartment as shiny as the manifold I guess
looks great, what steps did you take to cut down and polish the manifold?
You can see at the end of the last page,,, I started with a cut-off wheel,, then grinder, then dremel cut off, then 40 grit sandpaper all the way up to 400 grit cut into wet mothers aluminum polish,, followed by hours and hours of 0000 steel wool and mothers polishchongmang wrote:looks great, what steps did you take to cut down and polish the manifold?
