FS: TONS OF JDM/AFTERMARKET S13-S14 PARTS!!!
HAM8URGER
Postby HAM8URGER » 03 Jul 2013 09:28
-Vis carbon hood real Vis aero catch latches installed over 900 new for hood 225 for latches both are like new I'm asking 550 obo
-Real origin body kit it's called the stylish kit fits 95 /96 over 1200 retail asking 500 the Vis hood is also for 95/96
-300zx twin turbo trans 300.00 comes with shifter and carbon fiber shift knob differential was also from twin turbo
-300zx diff with axles much stronger than 240 diff asking 250.00 they usually go for 350.00
-Complete harness for rb25 series 1 to plug directly into s14 chassis came out of running vehicle also comes with ecu 300.00 swap harnesses online are over 700.00 and you also have to provide a core. This will allow rb25 to plug directly in with no wiring
-Real mines tuned ecu for rb26 asking 250.00
-Ka24 stock exhaust cams from early s13 they are much larger than factory s14 cams and a very cheap upgrade I have three sets 25.00 each set
-Spec stage three clutch for rb series engine 20 25 or 26 over 800.00 new asking 250.00 has good life left.
-Fresh built rb26 Manley rods ported head from endyne bronze valve guides 1mm over intake and exhaust valves hks step two cams 264 duration and Mls head gasket engine will come assembled 3,250 head alone was over 2,000 for parts and labor cams 700. Rods 550.00 again will be together and perfect with new parts for 3,250
-Brand new hid kit for 95/96 s14 plugs right in 100.00
-5 speed swap kit minus trans and pedal 125.00
-Brand new one piece dirge shaft for s14 KA24 engine 350.00 they are 450.00 or 500.00 new i think 350.00 is a hell of a price
-JDM center grillefor zenki 95/96 real JDM 60.00
-Complete own glass headlight set for 97/98 or conversion for zenki hid's installed they were on car for less than 500 miles both corners and headlights are in perfect condition 400.00
-Kouki 97/98 front bumper with glass fogs hid and lower lip these go for 500.00 without lower lip or fogs, i also have new side markers and turns for bumper asking 650.00 also comes with crash bumper for kouki and bumper support both are required when converting front end
-91 200zx twin turbo wire harness no issues 75.00
-Kouki center grill for 97/98 or zenki swap 70.00 like new
-Like new zenki headlights for 95/96 best ive seen since early 2000 200.00 for full set
-Also will sell neo rb25 for the right price it has Manley h beam rods all arp fasteners n1 oil pump n1 water pump fully ported head by endyne In ft. Worth Texas tomei poncams Mls head gasket perfect engine fresh build also have all accessories intake sensors throttle body manifold ready for install taking offers over 4,000 invested with machine costs and parts awesome engine best offer gets it.
FOR QUESTIONS OR MORE PICS CALL/TEXT BROCK AT: (270) 3one2-132zero
Re: FS: TONS OF JDM/AFTERMARKET S13-S14 PARTS!!!
Postby datzenmike » 03 Jul 2013 19:04
What are the dark areas on the cylinder tops? Looks like low spots?
HAM8URGER
Postby HAM8URGER » 03 Jul 2013 19:55
anyone interested?
HAM8URGER
Postby HAM8URGER » 03 Jul 2013 20:18
datzenmike wrote:What are the dark areas on the cylinder tops? Looks like low spots?
on any engine there will be carbon deposits on the top of the bore from the gap from the top of the piston to where the ring sits ...on EVERY motor. its 100% normal. if the ring was at the very top of the piston there would be too little material to hold the ringlands' integrity. if you have any other questions or want more pictures call or text the number i listed above.
HAM8URGER
Postby HAM8URGER » 08 Jul 2013 06:41
quick monday bump
iceD
Postby iceD » 08 Jul 2013 18:29
Where in hell r u?
ice D
Postby datzenmike » 08 Jul 2013 18:34
Sorry, I mean the eyebrow or quarter moon shape dark areas on the right sides.
HAM8URGER
Postby HAM8URGER » 19 Jul 2013 20:03
Friday bump
HAM8URGER
Postby HAM8URGER » 14 Sep 2013 09:23
still a ton of stuff for sale!
Return to “Non PL510 Projects”
