1200 within days
Re: 1200 within days
Post by two_68_510s » 08 Apr 2015 07:56
okayfine wrote:If your compressor housing is wider than your block, fun times are ahead!
Ha!!
Mattndew76
Post by Mattndew76 » 08 Apr 2015 08:02
Its setup for only 11lbs but I will pulley up for 15lbs.
The little motor will make an est 155-165 HP then. That's huge ponies for this go-kart.
Mattndew76
Post by Mattndew76 » 13 Apr 2015 10:36
What do you guys suggest for a 12 gal Fuel cel, and High pressure fuel pump?
Post by okayfine » 13 Apr 2015 10:43
How much do you care about buzzing? I like in-tank pumps for EFI. You can isolate the external aftermarket pumps so they don't buzz the chassis, but they still make a lot of noise. Some of the early Nissan EFI cars (280SX, 200SX) had external pumps and weren't loud from the factory. No idea if aftermarket replacements for those early pumps are noisy or not.
As to the fuel cell, it depends on where you're putting it. In a crush zone? I like poly and foam internals.
MtnGoat
Post by MtnGoat » 13 Apr 2015 10:52
I have a generic external electric pump on my wagon, installed last spring, and while you can hear a distinct pumping noise when the ign is on, once the engine starts you can't.
Mattndew76
Post by Mattndew76 » 13 Apr 2015 10:55
I dont really want a pinto style issue. The current B110 location of the factory tank is exactly in the wrong spot.
So maybe a poly tank & foam with an aluminum in car vapor cover?
Like one of these?
http://www.ebay.com/itm/NEW-RCI-12-GALL ... f4&vxp=mtr
Post by okayfine » 13 Apr 2015 11:58
Or build a cage around your fuel cell. Or the poly cell AND a cage.
I couldn't even buy material to make a cell for what that poly cell costs - and the RCI includes the sender, fittings, etc. I had ~$300 just in materials for the 19ga cell I built.
Mattndew76
Post by Mattndew76 » 13 Apr 2015 12:25
Its so hard to make a living doing small time stuff now days. Little guy cant get bulk cost on supplies hardly.
I think I will go Poly.
Sink a tank pan 6" down from the boot floor where the spare used to be.
Mattndew76
Post by Mattndew76 » 20 Apr 2015 07:57
Next for the car.
Mattndew76
Post by Mattndew76 » 21 Apr 2015 10:52
View-Able Valve cover tonight.
Mattndew76
Post by Mattndew76 » 23 Apr 2015 06:29
Post by okayfine » 23 Apr 2015 07:25
Nice. I was going to ask "why not a fabricated cover?" And then you showed that picture.
Mattndew76
Post by Mattndew76 » 23 Apr 2015 07:41
Overall cost to machine from a block is still less than to make a fab weld composite cover. Labor time and machine time.
At least in my case.
Mattndew76
Post by Mattndew76 » 27 Apr 2015 07:28
I like a bead blast finish best.
Post by okayfine » 27 Apr 2015 07:51
You could try the needle gun I used on my SR SU manifold, for that sand-cast look. Hard to go back from that, though.
