1200 within days
Mattndew76
Re: 1200 within days
Post by Mattndew76 » 30 Mar 2015 10:48
The CNC is home
Re-purposed work bench into a breakfast bar.
datso
Post by datso » 03 Apr 2015 17:38
You can make a whole billet 1200 bit by bit :)
or at least an A series in bottom end by making
the crankcase separate from the bore casings
like the ingenious Crossley Engine :D
then you can use any gearbox with a backing plate change
that also strengthens bottom and the top block sections.
Mattndew76
Post by Mattndew76 » 03 Apr 2015 21:07
I wouldn't even know where to begin.
datso
Post by datso » 04 Apr 2015 05:47
Yeah Crossley really was a genius with the mighty tin engine
Head and block was only 14.8lbs!!!! and was OHC gear driven!!
http://en.wikipedia.org/wiki/Crosley
I guess the only thing for the GA16de engine is if you want to run
a chain or belt as I feel the Z5 belt cam gears could be a good
upgrade to avoid running a chain unless you want to.
Ive yet to work out the GA valve angles compared to the Z heads.
Post by defdes » 04 Apr 2015 09:44
I looked him up after your initial post, never heard of him. Very cool stuff.
datso
Post by datso » 04 Apr 2015 19:16
some of his cars surely encouraged many brands like the datsuns with their small, economical, good performance and reliable. It was different thinking but as long as the old tin motor had proper coolant used which at that time was a real problem. I still wonder why they didnt use the Crossley into Indian like Bike frames would have been easier than building cars.
Matthew just found out the Ga16DS doesnt have the VVT to keep things cleaner and retro
https://www.google.co.jp/search?q=ga16d ... d=0CBwQsAQ
this DS is a 1.7 and around 160hp atw
https://www.youtube.com/watch?v=8EjA6YHi9Ew
http://www.nissanforums.com/ga16de-1-6l ... ost1251414
some porting, maybe gone overboard on the size but results are not shown, Peru is like the phillipines
where they carb anything and everything
http://velardejose.tripod.com/e16power/id12.html
Mattndew76
Post by Mattndew76 » 05 Apr 2015 15:46
Got a few things for the regular A12.
ARP Head studs, top end gasket kit, Paxton Compressor housing and 11psi fan, and pulley, EDIS kit, 40MM Throttle body, hmmmmm I think that's about it for now.
MtnGoat
Post by MtnGoat » 05 Apr 2015 23:05
What seats are those?
Mattndew76
Post by Mattndew76 » 06 Apr 2015 06:15
1989-Honda Si seats.
MtnGoat
Post by MtnGoat » 06 Apr 2015 08:01
thanks. They look pretty nice. I'm trying to figure out what to put in the roadster. Envy you that CNC machine too!
Mattndew76
Post by Mattndew76 » 06 Apr 2015 08:24
It takes a little saving but anyone can have one (CNC).
Just motivate to save.
I will sell you the pair of seats in that image. I have a spare set for myself. Mind that they need foam repair on the driver side bolsters.
MtnGoat
Post by MtnGoat » 06 Apr 2015 10:28
Hey thanks for the offer. I may take you up on that! How comfy are they with a nearly on the floor seat position?
My other choice was Four Runner seats, I have a set in my 510 'goon and they're super comfy.
Mattndew76
Post by Mattndew76 » 06 Apr 2015 12:22
I could drive 300 miles in these and feel ok getting up.
I love the adjustable lumbar and bolsters on the back rest.
Mattndew76
Post by Mattndew76 » 08 Apr 2015 07:30
Hair dryer installed. for now.
Post by okayfine » 08 Apr 2015 07:38
If your compressor housing is wider than your block, fun times are ahead!
