Barney
duke
Re: Barney
Post by duke » 19 May 2015 23:11
I'm going to put in a vote for no rings. I like the bare steelies or just the baby moons.
Re: Barney
Post by okayfine » 20 May 2015 10:46
I want to cover the hubs at least, I hate the bare hub nubs, especially up front.
Mattndew76
Re: Barney
Post by Mattndew76 » 20 May 2015 12:47
I vote Caps no rings :D
Re: Barney
Post by defdes » 20 May 2015 13:36
Mattndew76 wrote:I vote Caps no rings :D
x2...you know what they say about too much of a good thing.
Re: Barney
Post by okayfine » 29 May 2015 07:35
Made up a shroud for the mech fan. It's a 3/4 shroud, but ends at the bottom of the radiator core. It's split in half and bolts together, so I didn't have to pull the radiator to get it on. Bent up sides mount to the core support panel.
Working through some more fueling problems as well. Switched to an e-pump and wired it to an ignition-switched source, however the ATO fuse in the panel must have been old as dirt, since the 20A fuse popped about 3 miles down the road. Pump draws 2A, so, yeah. Got it home, replaced all the fuses with new fuses. Seems nothing's changed about fuses going from the Datsun glass fuses to ATO - they're good until they're bad, and they can look just fine and be on the verge of failure. :roll:
Re: Barney
Post by two_68_510s » 29 May 2015 07:55
Nice Julian, what about a small rolled bead of some kind around that inner edge? Seems like it might vibrate at speed. Plus it would be less sharp.
I wish I could weld the AL like that, my biggest challenge now, I need more practice time.
Re: Barney
Post by okayfine » 29 May 2015 08:22
No roller at hand, so no bead. Oh, and I didn't even think about it :mrgreen:
Re: Barney
Post by two_68_510s » 29 May 2015 09:39
I can send the manual one I made if you like, I don't think I will need it anytime soon. It would work great on that and would look cool.
beading tool.jpg (113.79 KiB) Viewed 2780 times
Re: Barney
Post by okayfine » 29 May 2015 09:57
Cool! What do you think about your tool on .065" aluminum, though?
Re: Barney
Post by two_68_510s » 29 May 2015 16:38
I will try it for you.
Re: Barney
Post by Byron510 » 29 May 2015 20:12
You know Joel, ever since you posted a photo of that tool nearly a year ago, I have wanted to make one. But I have not found the tool to start with! What did that tool start out as before modification?
Re: Barney
Post by two_68_510s » 29 May 2015 20:45
Yeah I bought cheap Chinese copies of those good ones!
Re: Barney
Post by two_68_510s » 29 May 2015 21:33
Tried it on all I had, some very stiff 0.05" frame. It seems to want to split if pushed too far, but if done gently
Re: Barney
Post by 510rob » 30 May 2015 02:12
was that aluminum sample annealed, or partially hard/tempered?
