Page 4 of 6
Re: Barney
Posted: 19 May 2015 23:11
by duke
I'm going to put in a vote for no rings. I like the bare steelies or just the baby moons.
Re: Barney
Posted: 20 May 2015 10:46
by okayfine
I want to cover the hubs at least, I hate the bare hub nubs, especially up front.
Re: Barney
Posted: 20 May 2015 12:47
by Mattndew76
I vote Caps no rings
Re: Barney
Posted: 20 May 2015 13:36
by defdes
Mattndew76 wrote:I vote Caps no rings
x2...you know what they say about too much of a good thing.
Re: Barney
Posted: 29 May 2015 07:35
by okayfine
Made up a shroud for the mech fan. It's a 3/4 shroud, but ends at the bottom of the radiator core. It's split in half and bolts together, so I didn't have to pull the radiator to get it on. Bent up sides mount to the core support panel.
- IMG_6516.jpg (227.55 KiB) Viewed 4964 times
Working through some more fueling problems as well. Switched to an e-pump and wired it to an ignition-switched source, however the ATO fuse in the panel must have been old as dirt, since the 20A fuse popped about 3 miles down the road. Pump draws 2A, so, yeah. Got it home, replaced all the fuses with new fuses. Seems nothing's changed about fuses going from the Datsun glass fuses to ATO - they're good until they're bad, and they can look just fine and be on the verge of failure.
Re: Barney
Posted: 29 May 2015 07:55
by two_68_510s
Nice Julian, what about a small rolled bead of some kind around that inner edge? Seems like it might vibrate at speed. Plus it would be less sharp.
I wish I could weld the AL like that, my biggest challenge now, I need more practice time.
Re: Barney
Posted: 29 May 2015 08:22
by okayfine
No roller at hand, so no bead. Oh, and I didn't even think about it
Re: Barney
Posted: 29 May 2015 09:39
by two_68_510s
I can send the manual one I made if you like, I don't think I will need it anytime soon. It would work great on that and would look cool.
- beading tool.jpg (113.79 KiB) Viewed 4955 times
Re: Barney
Posted: 29 May 2015 09:57
by okayfine
Cool! What do you think about your tool on .065" aluminum, though?
Re: Barney
Posted: 29 May 2015 16:38
by two_68_510s
I will try it for you.
Re: Barney
Posted: 29 May 2015 20:12
You know Joel, ever since you posted a photo of that tool nearly a year ago, I have wanted to make one. But I have not found the tool to start with! What did that tool start out as before modification?
Re: Barney
Posted: 29 May 2015 20:42
by 510rob
Re: Barney
Posted: 29 May 2015 20:45
by two_68_510s
Yeah I bought cheap Chinese copies of those good ones!
Re: Barney
Posted: 29 May 2015 21:33
by two_68_510s
Re: Barney
Posted: 30 May 2015 02:12
by 510rob
was that aluminum sample annealed, or partially hard/tempered?
