Interesting progress since the last update, it was one of those 2 steps backwards to go 3 steps forward. Normally I'd be pissed having to redo work, but in this case my patience (age) is keeping perspective of the long-term objectives.
After getting the rear subframe on and temporarily mounting the bed and cab, I realised that the rear frame stud brackets (to fasten the rear subframe) were way too high. The truck looked like a jacked up 4wd machine. Rather than resort to lowered suspension to eat up the gap, I knew that with a bit of effort I could have proper suspension geometry AND lower setup. So I cut the rear mounts almost 3" shorter and now the rear of the truck sits much better.
- RideHeight.jpg (66.94 KiB) Viewed 1158 times
While I was at it, I reinforced the rear frame rails to handle the increased torque from the VQ35DE. This will also provide mounting points for additional gussets off the frame bolt/studs, and for the new fuel tank.
- X_brace.jpg (96.19 KiB) Viewed 1158 times
Unfortunately, the front needed to now loose 1-2". The problem is that I couldn't lower the frame further down around the engine cross member because that would also lower the cab. The cab couldn't be lowered because the VQ intake manifold was at the top of the notched firewall and I didn't want to cut higher into upper cowl (wiper motor location).
That all changed one night when surfing YouTube and I noticed an interesting feature on a VQ35de swapped Toyota Corolla:
- YouTube.jpg (87.98 KiB) Viewed 1158 times
Somehow these guys managed to reverse the upper intake manifold. I have previously tried on my backup block but it turns out I didn't dive deep enough. The trick is to reverse the lower manifold (only), the two upper manifolds bolt the same only now facing backwards. There were some sacrifices, the rigid fuel line between the banks no longer fit, and some accessory bosses required cutting on the upper manifold. Plumbing will also have to be reworked. Regardless, I made the changes, including the decision to run a return fuel system (with flexible lines to suit my clearance requirements) instead of OEM returnless hardlines.
- ReverseManifold.jpg (93.24 KiB) Viewed 1158 times
This change not only gave me the 1.5" of height clearance to drop the frame further down around the engine, but it pulled the intake manifold right out of the cab! The limiter was no longer the firewall cowl but the hood.
- ManifoldHoodClearance.jpg (65.44 KiB) Viewed 1158 times
I can now close up much more of the firewall with a straight sheet of metal which *should* allow the OEM heater box to remain. I will still need a mild ~2" recess/hatch in the lower firewall to clear hard coolant lines and driver's valve cover, and to provide access for any troubleshooting.
- ReverseManifoldClearance.jpg (114.8 KiB) Viewed 1158 times
With the reverse intake manifold a feasible solution, I've since cut the frame's front subframe mounting bosses 1.5" (to allow it to sink further down around the engine). While the G35x front subframe was removed I decided to disassemble it and send it off for sandblasting to remove the copious amounts of rust. Once back, it will be permanently fastened, rather than the previously hoped bolt-in setup (I chickened out due to scope-creep and strength considerations).
Besides that, I've finally received all the proper bolts to install the clutch/tranny so it's now a single unit. Before closing things up I was sure to replace bushings & bearings, and the shifter fork pivot ball with a stronger aftermarket unit since the OEM ones have been known to self-decapitate.
- ShifterForkBall.jpg (73.74 KiB) Viewed 1158 times
Up next I should soon be receiving a brand new 720 19 gallon fuel tank. It will be in the same location as OEM, just in front of the rear axle and under the bed. It's a tight squeeze but I think I can make it work and the 50% extra capacity over the OEM 12 gallon tank will be nice. With that, the truck should be ready for a quick fire-up by mid-September. Better to test it now while the cab and bed are out of the way.
'72 Datsun 510 - MS KA24e, Watanabes, STI R180 w/CV axles, R&P assisted steering
'76 Datsun 280z - 2021 Datsun Restomods R&D project
