well, here goes nuthin...project number 2
Post by datzenmike » 31 Mar 2007 14:59
No you sounded like my dad.... "cut your hair and get a job!"
mattc
Post by mattc » 07 Apr 2007 07:50
been kinda cold - this it he latest. i have welded in the front corner, it's ready for finishing
Gravity: it's not just a good idea, it's the law!!
mattc
Post by mattc » 07 Apr 2007 07:53
hey - heres the new dually i just picked up! it's straight from Cali - no rust, 454 - she's real sweet!! has 3 fuel tanks, 644 liters of fuel...
Gensaiken1
Post by Gensaiken1 » 07 Apr 2007 14:12
your images broke
1971 2dr Datsun 510 - L20b, 219 SSS Head, Roundtop SU's
mattc
Post by mattc » 07 Apr 2007 15:32
the board has been real weird for images lately. i couldn't attach files to the reply, so i put them on photobucket and copied the link to my post. i can see them on the post, so i guess there is some stange happenings on the board lately!
joe510
Post by joe510 » 07 Apr 2007 17:06
Joe510 Anyone know where Ican get any info on carburator for a 1981 510 wagon
Post by datzenmike » 07 Apr 2007 19:40
Would that be a Z20S or maybe a Z22S motor? I have the truck manual for the Z20 and Z22 carbs.. if it's a simple question I may be able to look it up for you.
mattc
Post by mattc » 08 Apr 2007 11:37
stop hi-jacking my thread! got a question, start a new topic.
mattc
Update
Post by mattc » 06 May 2007 09:52
well, weather is better and the datsun is just about ready for the track
since last post i have:
finished the trunk
relocated the battery
installed new 3" 1/2x20 wheel studs
made bracket and intalled the fuel pump and filter
got the motor back together and degreed the cam in
changed the center section axle seals
got the new tires
modified the oil pan
fabbed a new oil cooler mount
made and installed headlight blocking plates
painted front flat black
finished trunk - note all panels were fitted first, then removed and framework was painted. All panels were sealed with silicone then riveted in place.
the fuel pump and filter - note NAS spec 1/4 x 28 bolts and silver plated steel lock nuts on cell and 1/4x 28 gr5 bolts and nuts on pump mount
rear wheel stud detail with 1/2" spacer - previous ownner was racing with incorrect lug nuts and only 2 threads of engagement - deadly.
mattc
degree in your cam
Post by mattc » 06 May 2007 10:02
it's been said many times but i have to say it again, if you don't degree in you cam you are asking for trouble.
when i installed my Colt Cam C.543 'striaght up', it was advanced 6.5 degrees! when i went to retard it using the positions on the factory cam wheel, it went forward another 6 degrees!! unreal. i put on another chain wheel from an L16 i had and P2 yielded the same, 6 degrees up, when i put it to P1 it went to 1/2 degree retarded. this is where it is now. but had i just put it in, the car would not have ran very well.
lots of thanks to Andy and Tracy at Specialty.
it's gonna go good!
use a big degree wheel to get accurate results.
the motor is going in tonight!!
mattc
almost running
Post by mattc » 21 May 2007 10:44
the motor is in, everything is ready to go, the rad doesn't fit. I call the guy i got the car from for the first time since i got it and asked him if he gave me the correct radiator, because the lower rad hose outlet hits the alternator on the one i have. turn out he never ran an alternator. oh well, there goes more money i didn't have.
engine with 45mm webers - how do i get a filter on there??
oil cooler has to wait until the rad goes in
hi tech duct tape always makes your car faster, especially when it's on the seat...
240sxsleeper
Post by 240sxsleeper » 28 Nov 2007 13:57
matt c. why did you cut that off? was it crinkeled? are you planning on welding a new peice?
