Lets see some welding and fabrication pics!
Re: Lets see some welding pics!
Post by okayfine » 27 Mar 2014 13:07
Another low-amp job from my L20BT project. This is the throttle wheel to actuate the SU, but I needed to weld it to another piece that itself mounted to the throttle shaft.
duke
Post by duke » 27 Mar 2014 13:20
goichi1 wrote:What were all of your other settings? initial arc? I know I can turn mine down but havent tried, I think I have to access the more hidden menus to do that. I have heard that's how people weld aluminum cans together.....I want to try....
There are tricks, but not with machine settings. I didn't use pulse or anything like that, just modulated the amps with the foot pedal. The hardest thing is getting them tacked. If you try to light up on the actual razor blade the hi freq will just blow the edge away. The trick is to clamp them to something (I used an aluminum block), then light up on the block and carefully move over to the blades. Also, if you start blowing a hole in them, you are pretty much done. There is no stopping and restarting, you must do the whole thing in one pass.
I tried some cans, but didn't really figure it out till about half way though, and by then I had already burned a couple of holes in them. Next time I have so cans around I'm going to try again though.
Track Junky
Post by Track Junky » 27 Mar 2014 13:30
One from the other day. This is the first few welds for my upcoming project. Double wishbone IRS.
Scott.
finn
Post by finn » 29 Mar 2014 19:28
Got the wife welding today. Building a safari rack for the jeep. Good that shes sharing interest.
'69 2dr KA24DET
finn
Post by finn » 29 Mar 2014 19:33
Damn phone! Sorry ill fix it soon.
'69 2dr KA24DET
Post by okayfine » 20 May 2014 12:30
Our compost bucket is steel, and despite paint and rust protection under that, it continues to rust due to the moisture in the compost. So I made an aluminum version.
Still needs handles, which I'll rob from the steel bucket before I kick it to the curb. Nothing really to save for another project, and I always save stuff for other projects (real, imagined, or unknown).
Post by Byron510 » 01 Jun 2014 22:23
Although not (yet) a welding project, I did machine up a couple replacement nuts to weld onto the transmission tunnel. One stripped out, and will need to be replaced one day on the Bronze. So I made a pair, and blew the dust off my little hobby lathe.
Turned out pretty good, I placed then next to the Greg Terry nuts on the floor and look identical. Felt good to use the lathe for a change.
DSC01519 (Medium).JPG (261.49 KiB) Viewed 2352 times
DSC01520 (Medium).JPG (259.08 KiB) Viewed 2352 times
Post by okayfine » 02 Jun 2014 05:59
We've got a thread for that! :mrgreen:
viewtopic.php?f=1&t=26653
PoorMtnKid
Post by PoorMtnKid » 02 Jun 2014 07:26
Byron510 wrote:Although not (yet) a welding project, I did machine up a couple replacement nuts to weld onto the transmission tunnel. One stripped out, and will need to be replaced one day on the Bronze. So I made a pair, and blew the dust off my little hobby lathe.
I need one of these my self, how hard would it be to spin up another?
Post by Byron510 » 02 Jun 2014 12:26
Turning them up is not hard at all - maybe 30 minutes to set up the first one - 10 minutes each afterwards.
Time is my greatest enemy - I'll try to make you a couple next time I'm out there.
Post by okayfine » 05 Nov 2014 11:39
Since this thread's been asleep for far too long, who needs a diamond-plate lunch box with quarter-turn fasteners? My wife.
Magnets glued to the underside of the top panel hold the steel key I made, shown in the next picture under the handle.
Post by defdes » 05 Nov 2014 14:18
okayfine wrote:Since this thread's been asleep for far too long, who needs a diamond-plate lunch box with quarter-turn fasteners? My wife.
Ooooh, what's that I smell........industrial cottage industry!
Re: Lets see some welding and fabrication pics!
Post by Byron510 » 08 Feb 2015 21:50
It's been a while since this thread got an addition - and it took e a while to find it so I added "fabrication" into the title....
Been busy this past week completing a roll cage for a friend of my shop mate. These guys have been running the Chumpcar series for a few years now in a mark II Golf, but want to step up their game. They have been very competitive on the west coast to date, so the build has experienced drivers behind the program. This is a mark IV car and will be turbocharged. The team was quite a professional lot to work with. Weight was a key factor, so a minimal cage to meet the various rule books was devised, fitting Chumpcar (which is as basic as I've ever seen), SCCA and CACC.
The door bars are currently just set in place, as the seat mounting has not yet been determined. The team runs many endurance events, - 24 and 36 hour events! There are 4 drivers, 5 for the longer enduros.
Cage turned out well. The car has a lot of curves, the A pillar bars were a real challenge getting them "right" Adding to tha - the A pillar bars needed to support the dash bar in exactly the right spot so that all items that were in the stock dash mount could be utilized within the cage design. I have to admit thought - this is a pretty big "small" car. Lots of room for the occupants.
IMG_2046 (Medium).JPG (236.52 KiB) Viewed 2123 times
IMG_2042 (Medium).JPG (199.08 KiB) Viewed 2123 times
IMG_2044 (Medium).JPG (148.03 KiB) Viewed 2123 times
Post by Byron510 » 08 Feb 2015 21:52
Here’s the dash bar comparison - factory vs built into the cage.
IMG_1886 (Medium).JPG (215.36 KiB) Viewed 2123 times
Post by Byron510 » 08 Feb 2015 22:00
The Chumpcar rule book allows one set of bars to protrude through the fire wall, so the team chose the strut towers as this is a known "soft spot" for this chassis design. But this meant punching holes through the pressurized cowl vent....more to come. And yes this car needs to run endurance events in the rain.
The driver’s side strut tower brace required a bend to clear the wiper linkage - this bar was a challenge.
IMG_2033 (Medium).JPG (91.14 KiB) Viewed 2120 times
IMG_2037 (Medium).JPG (198.48 KiB) Viewed 2121 times
IMG_2034 (Medium).JPG (162.64 KiB) Viewed 2121 times
