Jaguar Wood 1964 MrkII
- two_68_510s
Just refinished this wood for my friend Alan, he has an LS engine in this car, 1964 Mrk II.
It was ravaged by 10 years of leaky windshield rubber, required complete rebuild of main dash pieces
Job done!
Job done!
Re: Jaguar Wood 1964 MrkII
magnificent work, you are a true craftsman!
What wonderful work Joel! Care to share some of the process and materials used? I would not want to guess the number of hours you spent on that dash. Nice kitty too!
gorgeous car - gorgeous work.
- two_68_510s
Thanks guys.
To answer your question, Henk, pretty standard woodworking techniques.
I do use some newer chemicals to soften the veneer for flattening, and I like urethane glue because it can withstand temp changes better. Jaguar used American Black Walnut burl and some boxwood on this car. Fitting the veneers takes some time with color touch of joints and voids and bookmatching. Vacumn bag for the clamping process, goes to all the corners and shapes. Lots of scraping and sanding of wood, the smoother the finish the more clear the figure/grain is after finishing, For instance, if there was an irridescent figure in the grain that changes and moves when you move your head, it would be much more pronounced and sharp at 2000 grit then 600 grit.
Finish is 5-6 coats of catalyzed polyurethane high solids clear coat, this is Matrix brand. I reduce the first coat 10% or so so it penetrates the surface better, like a sealer coat.
Blocked to 2000 grit between coats and let cure for two days before each blocking, makes it flatter after the finish settles down. takes about 45 days for all of it.
Polish with large buffer and some lambs wool for cutting the finish. I do some buffing on a 1750 rpm 10" stationary buffer with a fat soft unsewn pad in it, easier to do the smaller pieces.
Standard polishing sequence for new clear automotive coat, be careful on the corners and ridges! The mechanics did the installation BTW, that is the scary part!
- McShagger510
Insane detail & craftsmanship!
'91 Nissan truck *SOLD*
'02 TOYOTA Tacoma
'02 TOYOTA Tacoma
I say, how much longer must I walk?!? Is my Jaguar repaired yet?!?
- GIF-sophisticated-cat.gif (1.03 MiB) Viewed 3908 times
- two_68_510s
LOL funny and close to the truth, the thing took 2 1/2 years to build, complete custom front suspension and new brakes (Wilwood)510rob wrote:I say, how much longer must I walk?!? Is my Jaguar repaired yet?!?
My wood was finished after about a year into it, He just got the rest done a couple of months ago.
- two_68_510s
Photos of the engine and ride stance:
there is a local guy in Vancouver (John Fluevog from Fluevog shoes fame) who has one hot rodded Jag and is working on another. My friends' shop did the work on the first one. If I can find some pics I will get the posted.
here is the first one:
https://www.fluevog.com/flueblog/johns-famous-flueguar/
- two_68_510s
WHOA!!I love it when folks just shape the metal and wood the way they want, take no prisoners, so much work, incredible!!dcuplover wrote:there is a local guy in Vancouver (John Fluevog from Fluevog shoes fame) who has one hot rodded Jag and is working on another. My friends' shop did the work on the first one. If I can find some pics I will get the posted.
