Bike rides
No worries. Post here to your hearts content
Re: Bike rides
Post by bertvorgon » 30 May 2018 08:41
Hike to Mount Slesse Memorial
I doubt the pilots even had a second of warning, at 520KM, when they slammed directly into the main wall of the third peak on Mt. Slesse and into oblivion. They are still there to this day, along with 60 other souls.
As another part of Matt and I getting ourselves into shape for our big summer hike, we upped the ante on this one by donning a heavier pack and doing some serious altitude gain. We had wanted to do a different hike and elected to drive out the Fraser valley and up the Chilliwack Lake road, then right up the Nesakwatch Creek FSR, to a point that we could not get over a huge washout with the Tracker.
This hike was to take us up to the Memorial plaque for the Trans-Canada flight #810, which crashed on Dec 9, 1956. I was aware of this crash back in the mid 1960’s, as a good friend at the times Dad, was to have been on this flight as Chief Steward for Trans-Canada airlines. His wife had some sort of very bad premonition about this flight, and, with great family stress, he had his shift changed, as she was just so adamant the he not go. Then later in 1969 -1975, I hiked on the West side of the mountain, looking for the long lost Red Mountain gold mine which I have written about. (I would post it on here if anyone was interested)
Matt and I got to the washout about 8:30, donning packs which felt like a brick on my back. There was light cloud cover so the temperature was perfect for hiking, even taking my fleece vest off after a few kilometers of uphill walking on the washed out road.
After about four kilometers we came to a small sign leading to the start of the uphill grind to the memorial plaque. The trail dropped very steeply to start, coming finally to a new bridge built last year, to cross the Nesakwatch Creek, now in full flow with spring runoff, brilliant in the morning sun.
Now the real climb began, a sliver of a trail carved out of the forest. As we got higher, incredible vistas of the mountains to the east were before us, thick wisps of fog and cloud swirling about the tops. This mountain across from us is on the serious climbers list to do, Mt. Rexford. Soon we saw snow ahead along the edge of the trail, letting us know we would soon be walking on it. I was hoping it would not be too soft.
One component of our hikes is breaking in our relatively new packs. It is like breaking in a new pair of boots. If you are a backpacker you will know what I mean. You need to get the hip belts and shoulder straps loosened up to really fit your body. Our packs have a pivot in the lower back so that when you walk, your hips can move without the shifting of the pack as you walk. Brilliant idea! I would buy a beer for the person at Black Diamond who came up with that idea. I finally retired my state of the art in 1970, external frame pack, for this new one and must admit it is quite nice.
We now were on about two to three feet of snow and thankfully it was still firm in the morning sun, which was slowly disappearing in clouds that kept rolling in from down the valley. Ahead was a sign requesting that this area was now legally a protected site due to the bodies still being here and the wreckage, none of which was recoverable due to the severity of the crash and the remoteness, let alone the avalanche danger.
We finally came to the memorial plaque and, one of the most incredible vistas ahead of us I have experienced, of Mt. Slesse, the peak shrouded in mist, shear walls of granitic rock, three small glaciers, waterfalls galore and the odd rumble as small avalanches tumbled down in the warming air of the morning. I must say for me it was quite the experience to think of those lost souls on the mountain, life over in a blink. As the plaque says, the MOUNTAIN is their memorial.
In reading the accident report, the pilot(s) made a fatal error and turned right, when they should have turned left, after reporting an engine fire issue. The weather was bad and requested traffic control to route them back to Vancouver, where the flight had just originated from. Both of them either miss heard Control and neither checked their compass headings. So by turning right, it got them right into the end of the Cascade range and they lost altitude to below the top of Slesse, at 8,000 feet, hitting the face at about 7,000 feet.
Matt and I stood there for quite awhile, just contemplating the entire vista before us, both for the natural beauty and the disaster that happened.
There is another memorial up higher from where we were, a cairn with wreckage and a propeller blade, which is even closer to the base of the actual wall of Slesse. We decided to head higher, but, ultimately turned around as the snow got deeper and with some bush whacking, was getting tough, the snow having flattened the clump maple over the trail. We will try to go back up there in another 3 weeks when the snow is gone. We headed back to the plaque for some much needed lunch, having burned up some serious calories to get to this 4,000 foot level.
The day had moved on so the trip down was just a case of put it into 3rd gear and down we went. That last 4 km back on the road was a bit of a slog and it sure felt good to get those boots off, we had just walked 14.2 km and did just over 4,000 feet of elevation change.
I have attached the link to the crash site info should you be curious. There was also the rumour/legend/myth that there was an Asian fellow carrying $80,000.00 dollars on the flight, that supposedly was never found or recovered.
https://en.wikipedia.org/wiki/Trans-Can ... Flight_810
IMGP3499 (Medium).jpeg (507.51 KiB) Viewed 378 times
IMGP3498 (Medium).jpeg (236.84 KiB) Viewed 378 times
IMGP3494 (Medium).jpeg (494.82 KiB) Viewed 378 times
IMGP3493 (Medium).jpeg (433.65 KiB) Viewed 378 times
IMGP3491 (Medium).jpeg (296.1 KiB) Viewed 378 times
IMGP3490 (Medium).jpeg (440.86 KiB) Viewed 378 times
IMGP3488 (Medium).jpeg (380.88 KiB) Viewed 378 times
IMGP3487 (Medium).jpeg (404.94 KiB) Viewed 378 times
IMGP3480 (Medium).jpeg (424.57 KiB) Viewed 378 times
Re: Bike rides
Post by bertvorgon » 30 May 2018 08:44
Some more
IMGP3513 (Medium).jpeg (331.13 KiB) Viewed 377 times
IMGP3511 (Medium).jpeg (326.79 KiB) Viewed 377 times
IMGP3510 (Medium).jpeg (333.91 KiB) Viewed 377 times
IMGP3509 (Medium).jpeg (351.18 KiB) Viewed 377 times
IMGP3508 (Medium).jpeg (347.3 KiB) Viewed 377 times
IMGP3507 (Medium).jpeg (296.97 KiB) Viewed 377 times
IMGP3506 (Medium).jpeg (349.38 KiB) Viewed 377 times
IMGP3505 (Medium).jpeg (352.38 KiB) Viewed 377 times
IMGP3504 (Medium).jpeg (457.97 KiB) Viewed 377 times
IMGP3501 (Medium).jpeg (331.72 KiB) Viewed 377 times
Re: Bike rides
Post by bertvorgon » 30 May 2018 08:46
More pics
IMGP3518 (Medium).jpeg (311.02 KiB) Viewed 377 times
IMGP3517 (Medium).jpeg (231.65 KiB) Viewed 377 times
IMGP3516 (Medium).jpeg (324.3 KiB) Viewed 377 times
IMGP3514 (Medium).jpeg (498.92 KiB) Viewed 377 times
Re: Bike rides
Post by bertvorgon » 30 May 2018 08:48
And final
Mt. Slesse (Small).jpeg (140.57 KiB) Viewed 376 times
20180526_105815 (Medium).jpg (363.06 KiB) Viewed 376 times
gooned
Re: Bike rides
Post by gooned » 30 May 2018 18:51
Great day out guys.
Re: Bike rides
Post by bertvorgon » 07 Aug 2018 11:29
#2 Hike to Mt. Slesse Memorial
I could not get the bug repellant out of my pack fast enough! In two seconds Matt and I were covered in black flies, some trying to rip a chunk of skin out.
This was hike number two up towards the Slesse Mountain Memorial, this time going past the memorial plaque and heading further up the mountain to the Propeller Cairn.
We were able to 4 x 4 over the big slide area that stopped us last time, as it had been beaten down over the last few months, lots of big tired trucks pushing the rocks back into B.C.. This saved us the long and tiring walk after exiting the trail at the end of the day, which turned out to be a good thing.
With the snow long gone the trail had really grown over again, even at a few places making it hard to see our feet and what might lurk under the bush. There are places where the dirt has washed out and left a nice ankle breaking hole for the unwary.
The smoke from all the forest fires made the mountains muted in colour, which was too bad, yet still spectacular.
We stopped at the first memorial for a quick snack and that is when the brutal attack came from the bugs. Wow, were they thick. I dragged the Deep Woods OFF out of the pack, spritzing my exposed flesh. I hate that stuff but, at times like this, chemical warfare is necessary! All the citronella, so called “green” stuff, just plain does not work. You need good ole’ 25% DEET to do the job, and that it did. The bugs would land then jump right off. A young couple showed up as we were leaving and they had not brought any bug spray. We took pity on them and shared our Deep Woods with them, the relief instantaneous.
From this point, last May, we were walking on 3 feet of snow, now it was just a bit of a bushwack, we could not even recognize the trail it had grown up so much. The trail then started to get really steep as we entered the tree line, following a narrow ridge. The day had rumbled on at this point, and after four hours of hiking we realized that we were not going to get to the Propeller Cairn, as a final, very steep push lay before us, at least another forty five minutes. If we factored in a lunch stop and a hike back, we would have been very late getting home and would have a couple of people worried.
We had our lunch in this alpine meadow, the heather in full bloom, mountain blueberries ripening in the hot sun. They were a bit tart but soon would be at full sugar content. While the bug spray was doing its job, we were still swarmed by them anyway, so sitting for any length of time was a bit tough.
With Mt. Slesse looming over us we headed back down, the afternoon shadows showing the day had moved on. Thankfully a good chunk of the trail is actually in the shade, as the heat of the day was cooking us in the open sun. I was smoking hot when we got down to the river again as humidity in the forest was very high.
The kilometer slog back to the vehicle had our feet DONE for the day, some 12 Km hiked and a 4,000 foot elevation day behind us.
One thing I really was glad that I did was take extra water! All the freshets were dry. I pity anyone that did not bring enough water as even above where we stopped, the snow was long gone. I packed 3 litres of water and sure felt that additional weight on the way up.
We lucked out on the drive back on #1, traffic flowed smoothly with no holdups!
Traffic was a nightmare on the Monday as everyone came home from the long weekend.
The Propeller Cairn still awaits us, just under the 6,000 ft level, surrounded by vertical walls of granite and glacier.
Keith law
August 7, 2018
IMGP3802 (Medium).jpeg (249.58 KiB) Viewed 88 times
IMGP3801 (Medium).jpeg (474.17 KiB) Viewed 88 times
IMGP3800 (Medium).jpeg (267.44 KiB) Viewed 88 times
IMGP3799 (Medium).jpeg (245.03 KiB) Viewed 88 times
IMGP3798 (Medium).jpeg (470.75 KiB) Viewed 88 times
IMGP3797 (Medium).jpeg (509.96 KiB) Viewed 88 times
IMGP3796 (Medium).jpeg (407.7 KiB) Viewed 88 times
IMGP3795 (Medium).jpeg (481.47 KiB) Viewed 88 times
Re: Bike rides
Post by bertvorgon » 07 Aug 2018 11:30
Last
IMGP3813 (Medium).jpeg (220.67 KiB) Viewed 88 times
IMGP3811 (Medium).jpeg (389.13 KiB) Viewed 88 times
IMGP3810 (Medium).jpeg (167.89 KiB) Viewed 88 times
IMGP3809 (Medium).jpeg (334.85 KiB) Viewed 88 times
IMGP3807 (Medium).jpeg (392.51 KiB) Viewed 88 times
KiKiIchiBan
Re: Bike rides
Post by KiKiIchiBan » 08 Aug 2018 11:37
Never get bored of looking at stunning scenery like that.
My Bluebird SSS Coupe #25
