Post
by proflex » 29 Aug 2010 19:12
So here are my plans for this car.
Chassis------------
#1 thing is fix all the rust. If this car had little to no rust it would have been left stock but unfortunately it does. On the up side it will give me the opportunity to change things slightly to some areas. Some of these things are
-strengthen and brace inner strut/fender area
-clearance the rear front inner fender area for larger tires
-raise a small area of floor, under gas pedal for more exhaust/header room
-lower sill ½ inch to wrap around backside of ugly lower body seam
-battery box in trunk floor
-maybe? shave vertical body seam on rear valance, horizontal seam will stay as it’s under the bumper
-raise/clearance rear inner fender for tire clearance –I’m planning on running 205s or 215s on 7 inch rims with proper rear toe/camber adjusted after lowering car
*-flares? It all depends on what I find under the bondo on the driver’s side rear fender lip. Looks like it had a parking lot love tap that was repaired very poorly. Both front and rear lower wheel well lips had to go because of rust. This lip is very hard to reproduce and even harder to make it look right. I will be able to run the wider tires with no problems if I flare the car. If flares go on I’m going to either graft on some donor steel fender flares {found some I kind of like, but we will see} or use some mid-sized glass old school BRE flares.
Drive train------------
-L20B, U67 head {ported?}, 445 cam, 32/36 Weber or a single Weber 48DCOE side draft , the good stock L16 manifold or one of my good headers - wideband installed , 2.25 or 2.5 exhaust
-dog leg 5 speed [not a big fan of this shift pattern]
-R160 dif, maybe a R180 [have to check its condition and ratio first]
Suspension ------------
-lowered {of course/low but not too low} front coilovers , adjustable inserts, camber plates, raised inner LCA mount, 15/16th front bar, shortened 510 struts for now with future upgrades after the car is up and running
- rear suspension = adjustable caster/camber, exhaust hole enlarged, strengthened rear arms, no rear bar, soft or adjustable rear shocks?
*I’m not sure about what spring ratios I’m going to run yet. On the high side I would start by running something like a 290 front/1100 rear {low side 250/900} but the back roads in my area can be very rough at times. I know everything in this area is a compromise but I was thinking I could maybe leave the ride height a little higher and soften up the shocks { will I have enough initial sag ?/do not want to top out} or maybe I will try and find a rear spring in the 1000lb area with front springs to match. I have read that specialty has 900lb and 1100lb springs but I’m thinking the 900lb would be too soft with no rear bar. Custom valved rear coilovers would make things much easier but an extra $1000+ is not in this builds budget. Maybe Merlin could loan me his money tree for a little while.
Brakes------------
-freshly serviced stock brakes with upgraded pads and shoes, fresh plumbing with adjustable proportioning valve mounted near driver.
Interior----------
Honda seats, 5 point belts, stock dash, mats and door panels. Headliner, four point role bar as well as some bead rolled aluminum panels are still up in the air at this point.
Paint job---------
-Stock blue color with white sides. Matching blue BRE side strips widened up a little with DATSUN, also in blue, through strips over sonic line. -----Will post picture of 510 with similar paint scheme, but only in yellow and white.
After car is in paint I will reassemble it with above mentioned parts and get it to a driveable state. Future tinkering and upgrades will be done to the car but only after time and money will allow. I’d rather be able to drive the car as well as work on it then have it sitting in my garage on stands. So there you have it. I promise the rest of my posts will be more pictures then words and not like this longwinded post.
PS. Please excuse any spelling/grammar mistakes in my posts. Even though I have many talents and skills in different areas, and did very well in my academics life, I’m afraid typing/spelling is not one of them...LOL.
----- Chad -----
- 510 at work with the work started on the chassis/body. No turning back now...
- 510 at home for more sheet metal work
- Change the yellow to blue and make the stips a little wider for my paint scheme
proflex on 03 Sep 2010 15:26, edited 1 time in total.
In just two days from now, tomorrow will be yesterday.
