Fuel pressure?
Fuel pressure?
i got a ka24e with dual webers and was wondering what the fuel psi should be to the carbs? ihave the stock 510 fuel pump, do i need an upgrade? and is there any bolt in upgrade?
Re: Fuel pressure?
They like 3.5, I think the stock pumps run about 7, though I can't confirm. Plenty of people use the stock pump so if you are not having any trouble, I wouldn't worry about it, though you could put in a pressure regulator too which would be cheaper/easier than an electric fuel pump.
Re: Fuel pressure?
The stock 510 L-series fuel pump bolts to and runs from the KA/E? I had no idea.
Re: Fuel pressure?
I would only imagine if it was one from an early carbed truck motor...okayfine wrote:The stock 510 L-series fuel pump bolts to and runs from the KA/E? I had no idea.
Pictures?!
richard norrish
Re: Fuel pressure?
My mental lapse there.okayfine wrote:The stock 510 L-series fuel pump bolts to and runs from the KA/E? I had no idea.
Re: Fuel pressure?
Pics of these aforementioned carbs/setup???
Re: Fuel pressure?
The OP should own that one, not you.defdes wrote:My mental lapse there.
Even if OP has the early carb head and is running a mech fuel pump off it, looking at the pictures of the KA/E head online it doesn't seem possible to use the stock 510 pump. The cam gear is larger/head is wider and would need a longer arm to reach the eccentric.
OP could provide some clarification...
Re: Fuel pressure?
heres a pic of my carb setup itshalf a stock ka24 manifold and half another manifold welded together. i bought the car like this and im not sure what fuel pump he ran, all i know is theres some big relays wired in the trunk. ill get some pics tomorrow.
- carb setup.jpg (4.13 KiB) Viewed 6068 times
Re: Fuel pressure?
Tiny picture, small like mice.
Your question was answered in post 2. You don't have a stock 510 pump. Pictures sound entertaining, but you'll need to measure the fuel pressure and figure out where to go from there. If it's necessary to add a fuel pressure regulator, avoid the "dial-a-just" cheapos and get the 1-4psi Holley regulator.
Re: Fuel pressure?
how do i make the pics big like billboards?
Re: Fuel pressure?
You can attach pictures here up to 250K in size. Your picture above is 4K, so there's room for increased pixel count. Alternatively you can put them up somewhere else and link them here. Lots of threads in Website Discussion regarding hosting photos.
Re: Fuel pressure?
make it 800-1000 pixels across VERY BIG
1500 1200 or a little smaller
800
800
Re: Fuel pressure?
Pictures get scaled down to fit the width of your browser window. In my case both of Joel's pictures are the same size, at least until I maximize the window.
In any case, Joel, have you been holding out on us? This the first time I've seen your front plate and accessory setup. Impressive.
- VelvetHammer
Re: Fuel pressure?
Agreed! Great looking plate Joel!okayfine wrote:Pictures get scaled down to fit the width of your browser window. In my case both of Joel's pictures are the same size, at least until I maximize the window.
Re: Fuel pressure?
(Sorry about the threadjack!) Updates in my build thread but here is a current photo of finished plate in aluminum:VelvetHammer wrote:Agreed! Great looking plate Joel!okayfine wrote:Pictures get scaled down to fit the width of your browser window. In my case both of Joel's pictures are the same size, at least until I maximize the window.
