Old school 510
Old school 510
It's time to start a build thread and even more important it's time to start building. Thanks for the welcome in the Introduction
I grew up in a 510 family. Two of my brothers and my sister drove them. My first 510 was a 72 wagon. Drove that car for a long time. My current 510 was my brother's first car. And the L20 engine I have in it came from another sister's totaled 610/710 I don't remember. As I mentioned in the intro. The car is straight and pretty much rustfree with the L20 and big 5 speed already installed. So it's a pretty good candidate for a makeover. The plans are as follows: install the SSS twin side drafts, clean up the body and get it repainted, install all new rubber, redo the interior. Freshen up the motor, adding 14" wheels/tires (since my 13" choices are severely limited) I'm also looking at a BRE style front spoiler and maybe the BRE fenders/ flares. Also going to look into updating the suspension and brakes.
progress pics to follow ( of course !!!)
1971 Datsun 510 2 door
08 VW R32
69 BSA 650 Firebird Scrambler
Too Many Bicycles
08 VW R32
Too Many Bicycles
Re: Old school 510
These pics were in my introduction thread. gotta start somewhere.
- 510-4.jpg (38.63 KiB) Viewed 15116 times
- 510-3.jpg (61.78 KiB) Viewed 15116 times
- 510-1.jpg (47.71 KiB) Viewed 15116 times
08 VW R32
Too Many Bicycles
08 VW R32
Too Many Bicycles
Re: Old school 510
ROLlOVER FROM Bike papa's INTRO POST:
Few things to consider before you pull this trigger; do you need everything? You may save some money only getting what you really need. It may take you a bit longer to track it all down though.
With the kit, you will not get the molded 1/4 window seals for the glass. What you get is one long straight piece that needs the corners miter cut to fit, because no one is making them anymore. I can tell you from first hand experience working with this crappy kit stuff is a serious pain in the ass. If yours are in OK condition I STRONGLY recommend doing anything and everything you can to save them. If you attempt to pull them apart for restoration be careful not to hack the rubber.
Either way you go you'll need make sure to specify what kind of front and rear windshield seals your looking for. There is a grooved version that accepts the stainless trim, or a "Cali" version thats smooth.
Best of luck on your build,
Ron M.
If you get everything in one big kit it's about $650 for every seal, trim, and plug in the car. I got mine from Rob's 510 parts. I've found him to be reasonable, reliable and nice to work with.Bike papa wrote: Any reccomendations for rubber sources? Is there anyone I should stay away from? C U in the project builds
Ron M.
510 rubber
Rod's
http://www.rodsdatsun.com/
Datsport
http://datsport.com/rubber-menu.html
New Datsun Parts
http://www.new-datsun-parts.com/datsun- ... ubber.html
More?
Datsport
New Datsun Parts
More?
- PoorMtnKid
Re: Old school 510
When you decided to do the suspension and breaks let me know. I have done the 280zx upgrade with ground control coilovers. Also made custom brackets to mount the 280zx rear discs to the car. Whats nice also you can ride in my car with the 250lbs springs and see if you want stiffer or softer. I did not have that luxuary availble to me, as no one i knew in vegas at the time had that done. If I did I prob would have gone with a 200-225 spring.
I also have the Ground control rear coil overs done, so it can give you an idea of what you may want
Re: Old school 510
Was your car always a Nevada car? IMHO, since the car is so straight, I wouldn't do flares, just clean up and paint.
Re: Old school 510
I'm with Mr. wizard on this one. A car that straight is gold.
Re: Old school 510
This car started it's life in SoCal. But it's been in LV for a long, long time. It was my daily driver for many years. I've always liked the BRE look butI the thought of cutting the rear fenders has always been an issue. Probably now more than ever. I think a mild suspension drop will give me the look I'm after. The time and effort might be better spent making the stock body xtra nice.
I tore into the weber yesterday. Every jet was plugged and the secondary butterfly was stuck closed. a good soaking cleaned everything up. Hopefully I"ll get it back on the car this week as well as installing the new hoses. Then get it running. I'm sure the gas tank will need to be flushed as well.
08 VW R32
Too Many Bicycles
08 VW R32
Too Many Bicycles
Re: Old school 510
Hydraulics will need to be gone through, too.
Re: Old school 510
Here's some pics of the car in it's new home. Definitely the "before" pics.
these sites are the best resource anyone could ask for when restoring a car.
25 yrs ago all i had was a book on how to hotrod and race your datsun. and the parts guy at the local nissan dealer.
this time around is going to be way more fun
gotta luv the internet!!!!!!!!
- Photo Jan 22, 11 54 16 AM.jpg (127.72 KiB) Viewed 14907 times
- Photo Jan 22, 11 55 32 AM.jpg (79.69 KiB) Viewed 14907 times
- Photo Jan 22, 11 50 36 AM.jpg (81.67 KiB) Viewed 14907 times
08 VW R32
Too Many Bicycles
08 VW R32
Too Many Bicycles
Re: Old school 510
just a couple more
- Photo Jan 22, 11 53 32 AM.jpg (140.89 KiB) Viewed 14901 times
- Photo Jan 22, 11 57 04 AM.jpg (105.08 KiB) Viewed 14901 times
08 VW R32
Too Many Bicycles
08 VW R32
Too Many Bicycles
- Dave Patten
Re: Old school 510
Bike papa,Bike papa wrote:This car started it's life in SoCal. But it's been in LV for a long, long time. It was my daily driver for many years. I've always liked the BRE look butI the thought of cutting the rear fenders has always been an issue. Probably now more than ever. I think a mild suspension drop will give me the look I'm after. The time and effort might be better spent making the stock body xtra nice...
I have to agree with you on cutting open the wheel openings for BRE flares. You've got such a clean and sound car, IMO I would keep the original fenders on it and spend the effort on them.
I would also suggest going to 15" wheels if you are going to upgrade in size. A good 14" tire is getting nearly as difficult to find as 13" are and it will only get worse over time.
195/50-15 on 15x6 +24 wheels look pretty good on a 510 with stock wheel opening.
Here is a photo of Terry Hackman's car. It might sway your opinion on tire size and body changes.
Re: Old school 510
After looking at some project builds I've decided NOT to add the flares. The wheel wells will remain stock.
I wanted that all along but a little positive reinforcement really helps. Thanks to all.
However I will be adding the BRE style front spoiler ( not cutting required!). Still on the fence about the "Cal" style windshield rubber
My windshield trim is in good shape but I still have time to decide.
08 VW R32
Too Many Bicycles
08 VW R32
Too Many Bicycles
Re: Old school 510
Yeahhhh!Bike papa wrote:After looking at some project builds I've decided NOT to add the flares.
And that comes from a guy who's flared a few of them!
Re: Old school 510
Your car looks like a great starting point. The body looks pretty dry and solid. I second all the votes for stock flares. There is still plenty of room under there.
Regarding the windshield rubber: I recently did a windshield replacement on one of the 510's in my family. We found NOS rubber that took the stainless strip to keep it stock looking. We found what was probably a chinese windshield through the glass shop here in Santa Cruz. They did a good job pulling the stainless trim and putting it all back in. It looks right and doesn't leak so far, although it hasn't had much water exposure. Like the stock flares, I like the stock stainless steel windshield trim as well. It's a cool bit on the 510!
'72 4 door 510, '68 2000 Roadster
