rebuilding half-shafts?
- Chadsinto510s
- SteveEdmonton
Re: rebuilding half-shafts?
Disassembled one half-shaft today. Here are some pics. Eventually you'll see the problem I uncovered along the way.
- IMG_5805 web.jpg (254.05 KiB) Viewed 5102 times
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
- SteveEdmonton
- SteveEdmonton
- SteveEdmonton
Another pic-- ready to come apart.
- IMG_5815 web.jpg (44.18 KiB) Viewed 5100 times
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
- SteveEdmonton
The balls & spacers-- note brownish colour of some!
- IMG_5818 web.jpg (41.15 KiB) Viewed 5096 times
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
- SteveEdmonton
Trying to keep the 4 sets of balls-and-spacers separate from each other, and associated with the correct races in the shaft. A filed notch on the end of the shaft is the key (it matches a notch filed on the axle tube, to keep them properly aligned as well).
- IMG_5819 web.jpg (43.91 KiB) Viewed 5096 times
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
- SteveEdmonton
Bad news though: the notchiness I felt while telescoping the shaft (on the bench) is due to these grooves/wear marks in the races. The brownish staining is obviously rust... yet these look simply like wear marks to me? In any case though, this is not good.
- IMG_5822 web.jpg (30.19 KiB) Viewed 5095 times
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
- SteveEdmonton
Another set of wear-marks in another of the races. Two of the four races are like this.
- IMG_5823 web.jpg (31.77 KiB) Viewed 5095 times
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
There is a mention in the body and chassis manual about replacing that o-ring.SteveEdmonton wrote:
- SteveEdmonton
Finally, the matching wear-marks in the outer part of the axle.
- IMG_5829 wear marks web.jpg (27.54 KiB) Viewed 5095 times
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
- SteveEdmonton
So, how serious is this wear in the races? As noted, I became aware of the problem only when telescoping the axle by hand on the bench. Didn't notice any problem while driving. Clean, grease, reassemble, drive? Or-- ?
The note about replacing that o-ring is helpful. I'll definitely want to do that, yeah.
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
I think all you can do is grease it up good and re assemble.
Chad.
Chad.
In just two days from now, tomorrow will be yesterday.
I don't think it would be an issue either, when they are on the car they just slide in and out a few inches if that....re-grease and put them back together....just does the old "in and out"
Do you want me to scan the page from the manual? It shows how to check the specs with a dial indicator to see if it's worn out and not usable.
