Finn's KA24DET
Finn's KA24DET
i've been aquiring pieces of this build for a little while now. i have a couple questions brewing so i figured its time to start a thread.
i'm using a older model turbonetics T3. no internal wastegate. i rebuilt it a short while ago, shaft play doesn't seem to excessive even dry of oil. there's no marks from blades striking the housing. the wastegate is a kospeed 8 psi 38mm. mitsubishi BOV. i picked up a N62 Maf out of a infinity today from a pull a part place as well as 370cc injectors from a SR20. it was a Pain in the Ass to get those injectors out of the fuel rail in one pieces. i had to use the two screws as leverage method. i was going to send them off to get a flow check but i think i'm going to clean them myself and see how they perform in the car now. i plan on using a side mount intercooler. the ECU is being tuned right now at R.S. Enthalpy. its a S13 ecu so i'm going to have to swap a few sensors and the complete harness. its going to be a pain because wrench-pro did a wire tuck for me when they did my swap. Martin is wiring in the consult port so i'm excited about that. i plan on using KA-t.org and 240sx for help through this but i'm going to document it primarily on here.
my first question is since im using the SR fuel injectors, should i use the SR fuel regulator?
- turbobuild3.jpg (111.59 KiB) Viewed 9946 times
- turbobuild2.jpg (214.71 KiB) Viewed 9946 times
'69 2dr KA24DET
Re: Finn's KA24DET
turbo
- turbo3.jpg (70.62 KiB) Viewed 9945 times
- turbobuild.jpg (182.92 KiB) Viewed 9945 times
- turbo2.jpg (66.9 KiB) Viewed 9945 times
'69 2dr KA24DET
Re: Finn's KA24DET
super 60?
Re: Finn's KA24DET
Turbonetics T3 .58 a/r .60. quite possibly but i don't know and their website doesn't have much for older models.
'69 2dr KA24DET
Re: Finn's KA24DET
Almost ready for install. Got the ecu but waiting on the adapter. Oil sandwich adapter, boost gauge, oil press. Gauge, and the manifold all came in. The manilfold looks pretty sturdy but I'm going to brace it regardless. The turbo alone weighs more. The wastegates will have to move. I got some nice thick flanges with it so I'm going to just weld a elbow facing down. I'm going to have to do some work on this manifold as well. The exhaust ports fail in comparison to the head.
- IMAG0644.jpg (124.31 KiB) Viewed 9821 times
- IMAG0646.jpg (175.1 KiB) Viewed 9821 times
'69 2dr KA24DET
Re: Finn's KA24DET
the oil kit looks interesting. the temp and press. mount right to it, but i heard they can have leaking issues. also, it derives its flow of fluid from the pressure feed so the oil is unfiltered, so i'll have to install a inline filter to preserve to journal bearings. the wideband was a must. the best part is that it has datalog so i can consistenly improve its tune.
- wideband.jpg (70.55 KiB) Viewed 9807 times
- oilkit.jpg (105.16 KiB) Viewed 9807 times
'69 2dr KA24DET
Re: Finn's KA24DET
Big turbo! Or small manifold.
I used to be a proponent of datalogging. But if you don't have rpm and TPS inputs along with the WBO2 readout, it isn't as helpful. Rolling around town with you eye on the non-datalogging gauge also has its problems, of course, but it works well enough if you aren't as connected.
Re: Finn's KA24DET
the A/F will pretty much stand as a diagnostic tool or an "idiot light" until i get a piggy back or something similar in place. the manifold is rather small but i'm going to use the power steering mounts on the block to hold a support bracket that will hopefully prevent it from cracking. it'll double as a mount for the heatshield for the brake booster.
'69 2dr KA24DET
Re: Finn's KA24DET
Busy day...
- IMAG0649.jpg (200.95 KiB) Viewed 9700 times
'69 2dr KA24DET
Re: Finn's KA24DET
the TC bushings were in dire need of replacement but the ball joints and tie rod ends were actually pretty good. which is well enough seeing that rockauto sent me a standard thread rod end for the drivers side instead of reverse thread the adjustable LCAs were built by Adam. i set left it at 1 degree caster 1/16 toe in. the front end stays glued to the road(rounded to the ground! unlike before, lots of drifting(not the fun kind). i didn't take any pics of the completed produce, sorry. i'll add them at a later date. i did however get the adapter for the ecu. my tuned ecu is for an S13, my KA is an S14. some folks wire these themselves, others pay. i got it from RS Enthapy because Martin is one nice fella. i'm going to keep praises low until its all hooked up and running, not that i don't trust them, just don't want to jinx it.
- ecuadapter.jpg (162.64 KiB) Viewed 9670 times
- tc bushing.jpg (148.29 KiB) Viewed 9670 times
'69 2dr KA24DET
Re: Finn's KA24DET
Just finished a trip to san Diego with the new LCAs. The drive wasn't too bad despite the loud exhaust and stiff suspension. Car handled great. $40 in gas for 380 miles isn't too bad either.... I got a couple early Xmas gifts from the mail while I was gone. The side mount Intercooler is from a '99 VW. That's not its final destination but I was going for that area. The boost controller and 2.5" tubing came in too. I'll need a couple reducers for the smic and compressor but all looks great. I want to get going on this but I promised my wife I'd have the M38 jeep put together and sold first so I need to get cracking on that.
- IMAG0655.jpg (144.05 KiB) Viewed 9590 times
- IMAG0654.jpg (180.2 KiB) Viewed 9590 times
'69 2dr KA24DET
Re: Finn's KA24DET
awesome project. are the injectors already in the running turbo motor??? The reason I ask is cause they look like red 259cc injectores out of a NA sr20de (which is the same for many NA nissan motors example ka24de and vg30de) not the 370cc injectors from a sr20det which tend to be purpleish grey. I'd hate for you to run lean and hurt the motor. Alas I could be wrong but it wouldnt hurt to check.
Re: Finn's KA24DET
Your handle sounds awfully familiar... But I haven't read your intro yet. My stock injectors are maroon 270cc from my understanding. The red top are 370cc. Purple were 500cc. I could be wrong as well and will look into this. I haven't installed them yet but plan to this weekend. I have new o rings on the way but wouldn't hurt to just keep them as back ups if I don't detect a leak
'69 2dr KA24DET
Re: Finn's KA24DET
What are the dimensions of that cooler (LxWxH)- and what model 99 VW? The core looks about the right size for my project as well.finn wrote:...side mount Intercooler is from a '99 VW...
Thanks in advance.
Re: Finn's KA24DET
'99 Passat. i measured the core itself but you can see in the photos that the inlet/outlet extend about two inches outward.
- intercoolersize3.jpg (81.92 KiB) Viewed 9503 times
- intercoolersize2.jpg (184.37 KiB) Viewed 9503 times
- intercoolersize.jpg (130.74 KiB) Viewed 9503 times
'69 2dr KA24DET
