N/A FJ20 Build
Re: N/A FJ20 Build
Post by defdes »
TUF510 wrote:no prob.
i may have one somewhere, just need to find it.. Will let you know by the end of the weekend
You know I forgot about the other FJ contingency here, I have been posting inquiries on FJ20.com and not getting any replies, just about worthless for info, really. Anyway, if you find one let me know, I am happy to avoid more fab when I can get away with it.
And Rob, thanks too, PM me what you are looking for for that set.
Is that Z31 TB from a VG30 C. '87-'88-'89? A bunch on ebay, just tyring to narrow it down.
Re: N/A FJ20 Build
510rob wrote:John, if you can't find a stock rail, you could make a similar fuel rail to what Byron made for his Bronze car
http://www.the510realm.com/viewtopic.ph ... &start=270
http://www.the510realm.com/download/fil ... &mode=view
http://www.rossmachineracing.com/dash6.html
I have a set of still-factory-sealed Bosch 0.280.150.007 injectors that I'll never use; I'll give you a deal if you are interested (or trade?). These are the same injectors that Byron is using in his N/A 2.2L engine, and the same ones that Jeff is using in his "gobstopper" car (mild turbo L20B)
http://www.witchhunter.com/flowdatapix/b0280150007.jpg
And as a base line, those injectors on the Bronze in the days of the big cam never saw more than 47% at 40 psi fuel pressure , meaning they are plenty big enough for my set up.
Re: N/A FJ20 Build
Post by 510rob »
I dug through FSMs for the Z31 300ZX setups. The ECU uses a two position throttle switch: one pin for idle, one pin for full throttle. The automatic cars appear to use a rheostat in the TPS; this signal is sent to the "Lock-up Control Unit" (transmission controller).
Take home point --> if you are looking for a throttle assembly from a Z31, then find one from a car with an automatic transmission. Could be a throttle from a Pathfinder or whatever, so long as it had a rheostat for an automatic transmission.
like this one --> CLICK HERE or CLICK HERE
The connector that is solid mounted to the body of the TPS is the switch, the connector that is hanging off to the side (by a wire) should be the rheostat connector/signal normally sent to the "LCU"
The water hoses are a preheat feature that you don't really need to use (could be trimmed off with a grinder/saw/gnarly file).
Re: N/A FJ20 Build
The 240SX one I have onthe latest Bronze EFI set up looked like these examples in the begining. Then I shortened the throttle shaft, changed the linkage, milled off the water heater area, ground off a few mounts that were no longer required, and there's no way in hell my TB is going back on a KA! 8) But it works just fine.
Re: N/A FJ20 Build
Post by defdes »
Byron510 wrote:The 240SX one I have onthe latest Bronze EFI set up looked like these examples in the begining. Then I shortened the throttle shaft, changed the linkage, milled off the water heater area, ground off a few mounts that were no longer required, and there's no way in hell my TB is going back on a KA! 8) But it works just fine.
Thanks for those links, one of those I was looking at last night. What's the deal with the double pull throttle linkage?
Re: N/A FJ20 Build
Post by 510rob »
I don't actually know, but I always assumed that one is for the throttle cable and the other is for a cruise control cable
Re: N/A FJ20 Build
510rob wrote:I don't actually know, but I always assumed that one is for the throttle cable and the other is for a cruise control cable
That's exactly what it's for, and why I got rid of it all.
TUF510
Re: N/A FJ20 Build
Post by TUF510 »
Sorry about the late reply.. i had a look and the one that i did find was bent and of no use to anyone and unfortunately its
not worth sending.
Some Boost in my FJ is good....More is better!!! :D
Re: N/A FJ20 Build
Post by defdes »
Thanks for checking, the project is going nowhere fast so if you run into another one let me know.
Cedric
Re: N/A FJ20 Build
Post by Cedric »
hmm looking good. I guess you are expert in all this work, because you done is very well.. and the engine is looking now better.. Thanks for sharing your project, I am waiting for its completion.. ..please keep sharing.
Rhino Rack Roof Racks
Re: N/A FJ20 Build
Post by defdes »
Thanks, not an expert, just eager to try and fail. I am in a holding pattern until Summer with the FI... work getting in the way of my good times.
FJDatto
Re: N/A FJ20 Build
Post by FJDatto »
I have an extra fuel rail, converted dizzy, and engine harness available if interested. The harness is from a Euro spec FJ and has all the ECCS hookups, to what, I don't know. Also, a 210 ecu, which you probably don't need.
Re: N/A FJ20 Build
Post by defdes »
I'd be interested in the fuel rail, would you put up a pic?
FJDatto
Re: N/A FJ20 Build
Post by FJDatto »
Using mine as a reference...
Hmm...apparently I'm not smart enough to post a picture...
FJDatto
Re: N/A FJ20 Build
Post by FJDatto »
Ah, there you go...
